It's my first time with ros and I installed using the RGB-D SLAM for "Not-yet" ROS Users (bottom of the page)
I'm able to run the following but no GUI shows up so after a few minutes of sitting there I ctrl+c. Am I missing something?
$ roslaunch rgbdslam kinect+rgbdslam.launch
... logging to /home/jackson/.ros/log/65d80698-bc6b-11e5-a420-000c29347746/roslaunch-ubuntu-4488.log
Press Ctrl-C to interrupt
started roslaunch server http://ubuntu:55220/
SUMMARY
PARAMETERS
 * /camera/depth/rectify_depth/interpolation
 * /camera/depth_registered/rectify_depth/interpolation
 * /camera/disparity_depth/max_range
 * /camera/disparity_depth/min_range
 * /camera/disparity_depth_registered/max_range
 * /camera/disparity_depth_registered/min_range
 * /camera/driver/depth_camera_info_url
 * /camera/driver/depth_frame_id
 * /camera/driver/depth_registration
 * /camera/driver/device_id
 * /camera/driver/rgb_camera_info_url
 * /camera/driver/rgb_frame_id
 * /rgbdslam/config/backend_solver
 * /rgbdslam/config/feature_detector_type
 * /rgbdslam/config/feature_extractor_type
 * /rgbdslam/config/g2o_transformation_refinement
 * /rgbdslam/config/gicp_max_cloud_size
 * /rgbdslam/config/icp_method
 * /rgbdslam/config/max_keypoints
 * /rgbdslam/config/min_matches
 * /rgbdslam/config/min_rotation_degree
 * /rgbdslam/config/min_sampled_candidates
 * /rgbdslam/config/min_time_reported
 * /rgbdslam/config/min_translation_meter
 * /rgbdslam/config/neighbor_candidates
 * /rgbdslam/config/nn_distance_ratio
 * /rgbdslam/config/observability_threshold
 * /rgbdslam/config/octomap_online_creation
 * /rgbdslam/config/octomap_resolution
 * /rgbdslam/config/predecessor_candidates
 * /rgbdslam/config/ransac_iterations
 * /rgbdslam/config/store_pointclouds
 * /rgbdslam/config/topic_image_depth
 * /rgbdslam/config/topic_image_mono
 * /rgbdslam/config/topic_points
 * /rgbdslam/config/use_icp
 * /rgbdslam/config/visualization_skip_step
 * /rgbdslam/config/visualize_keyframes_only
 * /rosdistro
 * /rosversion
NODES
  /camera/depth/
    metric (nodelet/nodelet)
    metric_rect (nodelet/nodelet)
    points (nodelet/nodelet)
    rectify_depth (nodelet/nodelet)
  /camera/rgb/
    debayer (nodelet/nodelet)
    rectify_color (nodelet/nodelet)
    rectify_mono (nodelet/nodelet)
    camera_base_link (tf/static_transform_publisher)
    camera_base_link1 (tf/static_transform_publisher)
    camera_base_link2 (tf/static_transform_publisher)
    camera_base_link3 (tf/static_transform_publisher)
    camera_nodelet_manager (nodelet/nodelet)
    rgbdslam (rgbdslam/rgbdslam)
  /camera/
    disparity_depth (nodelet/nodelet)
    disparity_depth_registered (nodelet/nodelet)
    driver (nodelet/nodelet)
    points_xyzrgb_depth_rgb (nodelet/nodelet)
    register_depth_rgb (nodelet/nodelet)
  /camera/ir/
    rectify_ir (nodelet/nodelet)
WARNING: [/home/jackson/ros/rgbdslam_freiburg/rgbdslam/launch/kinect+rgbdslam.launch] unknown <node> attribute 'no-launch-prefix'
auto-starting new master
process[master]: started with pid [4504]
setting /run_id to 65d80698-bc6b-11e5-a420-000c29347746
process[rosout-1]: started with pid [4517]
started core service [/rosout]
process[camera_nodelet_manager-2]: started with pid [4529]
process[camera/driver-3]: started with pid [4530]
[ INFO] [1452960516.664546337]: Initializing nodelet with 2 worker threads.
process[camera/rgb/debayer-4]: started with pid [4567]
process[camera/rgb/rectify_mono-5]: started with pid [4586]
process[camera/rgb/rectify_color-6]: started with pid [4602]
process[camera/ir/rectify_ir-7]: started with pid [4618]
process[camera/depth/rectify_depth-8]: started with pid [4633]
process[camera/depth/metric_rect-9]: started with pid [4650]
process[camera/depth/metric-10]: started with pid [4666]
process[camera/depth/points-11]: started with pid [4690]
process[camera/register_depth_rgb-12]: started with pid [4706]
process[camera/depth_registered/rectify_depth-13]: started with pid [4732]
process[camera/depth_registered/metric_rect-14]: started with pid [4756]
process[camera/depth_registered/metric-15]: started with pid [4779]
process[camera/points_xyzrgb_depth_rgb-16]: started with pid [4798]
process[camera/disparity_depth-17]: started with pid [4821]
process[camera/disparity_depth_registered-18]: started with pid [4834]
process[camera_base_link-19]: started with pid [4852]
process[camera_base_link1-20]: started with pid [4868]
process[camera_base_link2-21]: started with pid [4882]
process[camera_base_link3-22]: started with pid [4904]
ERROR: cannot launch node of type [rgbdslam/rgbdslam]: can't locate node [rgbdslam] in package [rgbdslam]
[ INFO] [1452960518.568452622]: Number devices connected: 1
[ INFO] [1452960518.568705891]: 1. device on bus 001:04 is a Xbox NUI Camera (2ae) from Microsoft (45e) with serial id 'A00363914834133A'
[ INFO] [1452960518.569645724]: Searching for device with index = 1
[ INFO] [1452960518.649156529]: Opened 'Xbox NUI Camera' on bus 1:4 with serial number 'A00363914834133A'
[ INFO] [1452960518.676101914]: rgb_frame_id = '/camera_rgb_optical_frame'
[ INFO] [1452960518.676375212]: depth_frame_id = '/camera_depth_optical_frame'
[ WARN] [1452960518.681387988]: Camera calibration file /home/jackson/.ros/camera_info/rgb_A00363914834133A.yaml not found.
[ WARN] [1452960518.681472281]: Using default parameters for RGB camera calibration.
[ WARN] [1452960518.681506199]: Camera calibration file /home/jackson/.ros/camera_info/depth_A00363914834133A.yaml not found.
[ WARN] [1452960518.681527988]: Using default parameters for IR camera calibration.
NOTE here is an issue I ran into before getting to this point.
Originally posted by jacksonkr_ on ROS Answers with karma: 396 on 2016-01-16
Comment by srik11 on 2016-01-17:
Hi!, Which sensor are you using? Is it the new kinect (Kinect for xbox one). I have tried using the new kinect but facing some issues with the usb port. I have been using the usb 3.0 port. But somehow cannot get the data from kinect. Wanted to know your inputs on how you got to run the kinect.
Comment by jacksonkr_ on 2016-01-18:
@srik11 I'm using the old kinect for xbox 360 on USB 3. It works with freenect but not with rgbdslam (yet)
Hi,
If you use openni, you can use this one:
roslaunch rgbdslam openni+rgbdslam.launch
Hope this helps
Originally posted by goupil35000 with karma: 113 on 2016-01-16
This works but for some reason my camera isn't connecting..
Comment by jacksonkr_ on 2016-01-28:
This wasn't working on my mac VM (ubuntu 12.04 amd64) but worked on a crappy HP laptop I bought (ubuntu 12.04.05 i386)
