i follow this answer:http://answers.ros.org/question/196455/kinect-installation-and-setup-on-ros-updated/ I understand Openni_launch does not work anymore under Indigo for Kinect so I install freenect_launch already it seems to connect the Kinect but not work correctly [ INFO] [1429730425.213607711]: Starting a 3s RGB and Depth stream flush. [ INFO] [1429730425.221435448]: Opened 'Xbox NUI Camera' on bus 0:0 with serial number 'A70773X01270231A' [ WARN] [1429730425.381519441]: Could not find any compatible depth output mode for 1. Falling back to default depth output mode 1. [ INFO] [1429730425.444282494]: rgb_frame_id = 'camera_rgb_optical_frame' [ INFO] [1429730425.444783170]: depth_frame_id = 'camera_depth_optical_frame' [ WARN] [1429730425.552470857]: Camera calibration file /home/sony/.ros/camera_info/rgb_A70773X01270231A.yaml not found. [ WARN] [1429730425.560671122]: Using default parameters for RGB camera calibration. [ WARN] [1429730425.572181403]: Camera calibration file /home/sony/.ros/camera_info/depth_A70773X01270231A.yaml not found. [ WARN] [1429730425.576274468]: Using default parameters for IR camera calibration. process[camera_base_link1-20]: started with pid [11928] process[camera_base_link2-21]: started with pid [11973] [ INFO] [1429730428.225654320]: Stopping device RGB and Depth stream flush.
thank you for help!
Originally posted by sony on ROS Answers with karma: 16 on 2015-04-22
Comment by marguedas on 2015-04-22:
Can you give more information about "but not work correctly" ?
What doesnt work ?
Do you receive images?
Be aware that by default freenect_launch does not enable depth_registration, you can emable it either by modifying the launchfile or using the GUI rqt_reconfigure
