Hi, I want to see the output of the 3DSensors of the turtlebot in simulation in gazebo.
I am launching turtlebot in gazebo using command:
roslaunch turtlebot_gazebo turtlebot_empty_world.launch
then,
roslaunch turtlebot_bringup minimal.launch
then.
roslaunch turtlebot_bringup 3dsensor.launch
then, Its showing:
started roslaunch server http:// localhost:53453/
SUMMARY
PARAMETERS
  • /camera/camera_nodelet_manager/num_worker_threads
  • /camera/depth_rectify_depth/interpolation
  • /camera/depth_registered_rectify_depth/interpolation
  • /camera/disparity_depth/max_range
  • /camera/disparity_depth/min_range
  • /camera/disparity_registered_hw/max_range
  • /camera/disparity_registered_hw/min_range
  • /camera/disparity_registered_sw/max_range
  • /camera/disparity_registered_sw/min_range
  • /camera/driver/depth_camera_info_url
  • /camera/driver/depth_frame_id
  • /camera/driver/depth_registration
  • /camera/driver/device_id
  • /camera/driver/rgb_camera_info_url
  • /camera/driver/rgb_frame_id
  • /depthimage_to_laserscan/output_frame_id
  • /depthimage_to_laserscan/range_min
  • /depthimage_to_laserscan/scan_height
  • /rosdistro
  • /rosversion
NODES /camera/ camera_nodelet_manager (nodelet/nodelet) debayer (nodelet/nodelet) depth_metric (nodelet/nodelet) depth_metric_rect (nodelet/nodelet) depth_points (nodelet/nodelet) depth_rectify_depth (nodelet/nodelet) depth_registered_rectify_depth (nodelet/nodelet) disparity_depth (nodelet/nodelet) disparity_registered_hw (nodelet/nodelet) disparity_registered_sw (nodelet/nodelet) driver (nodelet/nodelet) points_xyzrgb_hw_registered (nodelet/nodelet) points_xyzrgb_sw_registered (nodelet/nodelet) rectify_color (nodelet/nodelet) rectify_ir (nodelet/nodelet) rectify_mono (nodelet/nodelet) register_depth_rgb (nodelet/nodelet) / depthimage_to_laserscan (nodelet/nodelet)
ROS_MASTER_URI=http:// localhost:11311
core service [/rosout] found process[camera/camera_nodelet_manager-1]: started with pid [5376] process[camera/driver-2]: started with pid [5399] [ INFO] [1386525391.401574172]: Initializing nodelet with 4 worker threads. process[camera/debayer-3]: started with pid [5434] process[camera/rectify_mono-4]: started with pid [5450] process[camera/rectify_color-5]: started with pid [5467] process[camera/rectify_ir-6]: started with pid [5483] process[camera/depth_rectify_depth-7]: started with pid [5500] [ INFO] [1386525391.957140970]: No devices connected.... waiting for devices to be connected process[camera/depth_metric_rect-8]: started with pid [5516] process[camera/depth_metric-9]: started with pid [5534] process[camera/depth_points-10]: started with pid [5552] process[camera/register_depth_rgb-11]: started with pid [5569] process[camera/points_xyzrgb_sw_registered-12]: started with pid [5585] process[camera/depth_registered_rectify_depth-13]: started with pid [5603] process[camera/points_xyzrgb_hw_registered-14]: started with pid [5621] process[camera/disparity_depth-15]: started with pid [5639] process[camera/disparity_registered_sw-16]: started with pid [5656] process[camera/disparity_registered_hw-17]: started with pid [5672] process[depthimage_to_laserscan-18]: started with pid [5690] [ INFO] [1386525394.962265431]: No devices connected.... waiting for devices to be connected [ INFO] [1386525397.966016741]: No devices connected.... waiting for devices to be connected
PLZ help anyone... THANKS in advance...
Originally posted by DPK27 on ROS Answers with karma: 5 on 2013-12-08
Assumes that you are using hydro.
To simulate turtlebot, you don't have to launch minimal and 3d sensor. You can control both 3d sensor and robot with the command below.
or
roslaunch turtlebot_gazebo turtlebot_playground.launch
/camera/depth/points will give you 3d data. check with this command
rostopic bw /camera/depth/points
or bringup rviz and see.
roslaunch turtlebot_rviz_launchers view_robot.launch
Originally posted by jihoonl with karma: 634 on 2013-12-10
