Hello,
I'm getting the following error when trying to execute rosdep update
on my youbot running ros hydro (hint: I also have ros fuerte installed) on an Ubuntu 12.04 LTS:
`AssertionError: Unable to handle 'index' format version '2', please update rosdistro`
The complete Stacktrace:
File "/usr/local/lib/python2.7/dist-packages/rosdep2/main.py", line 121, in rosdep_main
exit_code = _rosdep_main(args)
File "/usr/local/lib/python2.7/dist-packages/rosdep2/main.py", line 264, in _rosdep_main
return _no_args_handler(command, parser, options, args)
File "/usr/local/lib/python2.7/dist-packages/rosdep2/main.py", line 272, in _no_args_handler
return command_handlers[command](options)
File "/usr/local/lib/python2.7/dist-packages/rosdep2/main.py", line 437, in command_update
error_handler=update_error_handler)
File "/usr/local/lib/python2.7/dist-packages/rosdep2/sources_list.py", line 433, in update_sources_list
for d, dist in get_index().distributions.items():
File "/usr/local/lib/python2.7/dist-packages/rosdep2/rosdistrohelper.py", line 58, in get_index
_RDCache.index = rosdistro.get_index(_RDCache.index_url)
File "/usr/local/lib/python2.7/dist-packages/rosdistro/__init__.py", line 109, in get_index
return Index(data, base_url)
File "/usr/local/lib/python2.7/dist-packages/rosdistro/index.py", line 50, in __init__
assert int(data['version']) == 1, "Unable to handle '%s' format version '%d', please update rosdistro" % (Index._type, int(data['version']))
This question has been asked for ROS Groovy here: http://answers.ros.org/question/122266/how-can-i-fix-unable-to-handle-index-format-version-2-please-update-rosdistro/ and there is also a related question here: http://answers.ros.org/question/49143/problems-with-rqt-groovy-ubuntu/?answer=49153#post-id-49153
However the soulations provided in these questions don't fix the problem I have.
Originally posted by Jabro on ROS Answers with karma: 5 on 2014-02-16
Comment by ahendrix on 2014-02-16:
Which OS is your youbot running? Which version of rosdep do you have installed?
Comment by Jabro on 2014-02-17:
I'm running Ubuntu 12.04 LTS, I'll check the rosdep verison later, when I have access to the robot
rosdep version is 0.10.25-1 for python 2.7
Comment by Dirk Thomas on 2014-02-17:
The package is question is not rosdep but rosdistro. Please check the version of that pcakage - it must be 0.3.x. You can check with: python -c "import rosdistro; print(rosdistro.version)"
Comment by Jabro on 2014-02-18:
I checked it, the version is 0.2.17.
I tried apt-get install --reinstall python-rosdistro, the console output stated that it is installing 0.3.4-1, but the error is still present and executing python -c "import rosdistro; print(rosdistro.version)" still leads to 0.2.17. How can I upgrade?
