Since yesterday I've been having a problem to use the next command:
$ rospack depends1 rospy
And any other command like this.
I receive the next output:
failed to load symbols, rosdep will not function properly Cannot import rospkg, rosdep will not function properly Traceback (most recent call last): File "/usr/lib/pymodules/python2.7/rosdep2/rospack.py", line 37, in import subprocess File "/usr/lib/python2.7/subprocess.py", line 429, in import select ImportError: No module named select Error in sys.excepthook: Traceback (most recent call last): File "/usr/lib/python2.7/dist-packages/apport_python_hook.py", line 61, in apport_excepthook from io import StringIO File "/usr/lib/python2.7/io.py", line 51, in import _io ImportError: /usr/lib/python2.7/lib-dynload/_io.so: undefined symbol: PyUnicodeUCS4_EncodeUTF32
Original exception was: Traceback (most recent call last): File "/usr/lib/pymodules/python2.7/rosdep2/rospack.py", line 37, in import subprocess File "/usr/lib/python2.7/subprocess.py", line 429, in import select ImportError: No module named select Traceback (most recent call last): File "/usr/lib/pymodules/python2.7/rosdep2/rospack.py", line 37, in import subprocess File "/usr/lib/python2.7/subprocess.py", line 429, in import select ImportError: No module named select Error in sys.excepthook: Traceback (most recent call last): File "/usr/lib/python2.7/dist-packages/apport_python_hook.py", line 61, in apport_excepthook from io import StringIO File "/usr/lib/python2.7/io.py", line 51, in import _io ImportError: /usr/lib/python2.7/lib-dynload/_io.so: undefined symbol: PyUnicodeUCS4_EncodeUTF32
Original exception was: Traceback (most recent call last): File "/usr/lib/pymodules/python2.7/rosdep2/rospack.py", line 37, in import subprocess File "/usr/lib/python2.7/subprocess.py", line 429, in import select ImportError: No module named select [rospack] Error: could not find python module 'rosdep2.rospack'. is rosdep up-to-date (at least 0.10.4)?
I'm using Ubuntu 12.10 (Quantal), with ROS-HYDRO.
My rosdep version is:
$ rosdep --version
0.10.25
I've already tried to find some solution, but I couldn't. I've tried to 'autoremove' ros and clean install again, but nothing changed.
When I try to 'import select' using the python environment in terminal, everything is OK.
My PYTHONPATH is OK, as follows:
$ echo $PYTHONPATH
/home/usr/catkin_ws/devel/lib/python2.7/dist-packages:/opt/ros/hydro/lib/python2.7/dist-packages
Can anybody help me please?
Originally posted by mah_mpc on ROS Answers with karma: 16 on 2014-04-04
Comment by mah_mpc on 2014-04-06:
Thanks for trying to help! I had some other problems with my ubuntu and so I re-installed everything! Now I don't have that problem anymore, neither the other problems... =)
Can you say how to reproduce your environment? It looks like you have several custom paths. Or can you reproduce this with a minimal environment to isolate the problem?
Originally posted by tfoote with karma: 58457 on 2014-04-04
I discovered why I had that problem! Like tfoote thought, I have some custom paths, and the python paths got into a conflict! I just organized them and everything is in ok now!
Originally posted by mah_mpc with karma: 16 on 2014-04-08
Comment by asiron on 2014-06-02:
Could you please tell me what was your problem, I have been having the same problem for 2 weeks, and I have yet to solve it, my env variables seem ok to me
Comment by mah_mpc on 2014-06-02:
As I'm working with NAO robot, I indicate its paths in the .bashrc file, one of them indicates the $PYTHONPATH. This path got into a conflit with the paths in ~/catkin_ws/devel/setup.bash. Everything was solved when I put the source ~/catkin_ws/devel/setup.bash AFTER exporting the NAO's python path.
Hope it helps! =)
