Hi,
I am trying to install a ros package on ubuntu 16.04 and ros kinetic version. However, the rosdep init seems to give following error:
Traceback (most recent call last): File "/usr/bin/rosdep", line 3, in from rosdep2.main import rosdep_main File "/usr/lib/python2.7/dist-packages/rosdep2/__init__.py", line 45, in from .lookup import RosdepDefinition, RosdepView, RosdepLookup, \ File "/usr/lib/python2.7/dist-packages/rosdep2/lookup.py", line 44, in from .sources_list import SourcesListLoader File "/usr/lib/python2.7/dist-packages/rosdep2/sources_list.py", line 49, in from .gbpdistro_support import get_gbprepo_as_rosdep_data, download_gbpdistro_as_rosdep_data File "/usr/lib/python2.7/dist-packages/rosdep2/gbpdistro_support.py", line 18, in from .platforms.debian import APT_INSTALLER File "/usr/lib/python2.7/dist-packages/rosdep2/platforms/debian.py", line 34, in from rospkg.os_detect import OS_DEBIAN, OS_LINARO, OS_UBUNTU, OS_ELEMENTARY, OS_MX, OsDetect, read_os_release ImportError: cannot import name OS_MX
This seems some python issue, but I have tried reinstalling: rosdep, ros kinetic, python and even did a reset of bashrc. If I remove the OS_MX, some OS_EMBEDDDED gives import error.
Rospkg version is 1.1.9
What could be the case here?
Originally posted by elementaryshr on ROS Answers with karma: 28 on 2019-05-30
Comment by gvdhoorn on 2019-05-30:
A guess, but seeing as you're on Ubuntu 14.04: it could be that rospkg
is not up-to-date enough on your system. Causing rosdep
to fail when it tries to import symbols that should be part of rospkg
but aren't on your system.
Comment by elementaryshr on 2019-05-30:
Thanks @gvdhoorn,
The rospkg is also up to date (V 1.19)
Did you mean to write 1.1.9
Just noticed this:
ubuntu 14.04 and ros kinetic version
Kinetic is not supported on Ubuntu 14.04; are you building things from source or is this a typo?
I am extreamly sorry, I typed out both the things rather quickly.
The Ubuntu version is 16.04.6 The rospkg is also 1.1.9
I have installed it via package manager.
Comment by Orhan on 2019-05-31:
Have you tried upgrading packages: sudo apt update && sudo apt upgrade
before installing?
Comment by elementaryshr on 2019-05-31:
Yes indeed. All the packages are up to date
Comment by Sensenzhl on 2021-12-24:
Have you solved the problem? I meet this problem too today.
