Hi!
I'm new to to ROS and Linux. I'm running ROS Fuerte on Ubuntu 12.04.
While going through the "BuildingPackages" tutorial I experienced a problem. After typing
rosdep install turtlesim
I get the error message:
ERROR: Rosdep experienced an internal error: 'NoneType' object has no attribute 'copy' Please go to the rosdep page [1] and file a bug report with the stack trace below. [1] : http://www.ros.org/wiki/rosdep
File "/usr/local/lib/python2.7/dist-packages/rosdep-0.9.3-py2.7.egg/rosdep2/main.py", line 111, in rosdep_main exit_code = _rosdep_main(args) File "/usr/local/lib/python2.7/dist-packages/rosdep-0.9.3-py2.7.egg/rosdep2/main.py", line 232, in _rosdep_main return _package_args_handler(command, parser, options, args) File "/usr/local/lib/python2.7/dist-packages/rosdep-0.9.3-py2.7.egg/rosdep2/main.py", line 255, in _package_args_handler lookup = _get_default_RosdepLookup(options) File "/usr/local/lib/python2.7/dist-packages/rosdep-0.9.3-py2.7.egg/rosdep2/main.py", line 103, in _get_default_RosdepLookup lookup = RosdepLookup.create_from_rospkg(sources_loader=sources_loader) File "/usr/local/lib/python2.7/dist-packages/rosdep-0.9.3-py2.7.egg/rosdep2/lookup.py", line 298, in create_from_rospkg lookup._load_all_views(loader=sources_loader) File "/usr/local/lib/python2.7/dist-packages/rosdep-0.9.3-py2.7.egg/rosdep2/lookup.py", line 426, in _load_all_views self._load_view_dependencies(resource_name, loader) File "/usr/local/lib/python2.7/dist-packages/rosdep-0.9.3-py2.7.egg/rosdep2/lookup.py", line 448, in _load_view_dependencies loader.load_view(view_key, db, verbose=self.verbose) File "/usr/local/lib/python2.7/dist-packages/rosdep-0.9.3-py2.7.egg/rosdep2/sources_list.py", line 505, in load_view rosdep_db.set_view_data(view_name, source.rosdep_data, view_dependencies, view_name) File "/usr/local/lib/python2.7/dist-packages/rosdep-0.9.3-py2.7.egg/rosdep2/model.py", line 89, in set_view_data self._rosdep_db[view_name] = RosdepDatabaseEntry(rosdep_data.copy(), view_dependencies, origin) AttributeError: 'NoneType' object has no attribute 'copy'
Maybe I somehow messed up my installation... I already did a reinstallation of Fuerte but the problem persists.
For I'm absolutely new to ROS and Ubuntu I have no clue how to solve or even further analyze the problem. I would very much appreciate any hints what to do at this point?
Thank you very much!
EDIT:
It's this part of the tutorial I have the mentioned problems with.
When I run
$ sudo rosdep init
I get
malte@ubuntu:~$ sudo rosdep init
[sudo] password for malte:  ERROR: default sources list file already exists:
    /etc/ros/rosdep/sources.list.d/20-default.list
Please delete if you wish to re-initialize
When I run
$ rosdep update
malte@ubuntu:~$ rosdep update
reading in sources list data from /etc/ros/rosdep/sources.list.d
Hit https://github.com/ros/rosdistro/raw/master/rosdep/osx-homebrew.yaml
Hit https://github.com/ros/rosdistro/raw/master/rosdep/gentoo.yaml
Hit https://github.com/ros/rosdistro/raw/master/rosdep/base.yaml
Hit https://github.com/ros/rosdistro/raw/master/rosdep/python.yaml
ERROR: unable to process source [https://github.com/ros/rosdistro/raw/master/releases/fuerte.yaml]:
Failed to download target platform data for gbpdistro:  invalid repo spec
in gbpdistro data: You must update to a newer rosdep version by calling..
    sudo apt-get update && sudo apt-get install python-rosdep
(make sure to uninstall the pip version on Ubuntu)
ERROR: unable to process source [https://github.com/ros/rosdistro/raw/master/releases/groovy.yaml]:
Failed to download target platform data for gbpdistro:  invalid repo spec in gbpdistro data:
updated cache in /home/malte/.ros/rosdep/sources.cache
As suggested by the error message I then ran
$ sudo apt-get update
which worked without errors. Running
$ sudo apt-get install python-rosdep
led to the message that the newest version of "python-rosdep" is already installed and that packages "libblas-dev" and "liblapack-dev" were automatically installed.
EDIT #2:
For
$ which rosdep
answered "/usr/local/bin/rosdep" I uninstalled rosdep as suggested below:
malte@ubuntu:~$ sudo pip uninstall rosdep [sudo] password for malte:  Uninstalling rosdep:   /usr/bin/rosdep /usr/bin/rosdep-gbp-brew   /usr/bin/rosdep-source   /usr/local/lib/python2.7/dist-packages/rosdep-0.9.3-py2.7.egg Proceed (y/n)? y   Successfully uninstalled rosdep
I though I then had to install the newest version:
$ sudo pip install -U rosdep
but afterwards
$ which rosdep
again aswered with "/usr/local/bin/rosdep"
Furthermore
$ rosdep install turtlesim
again led to the error as before:
Is there a way to get rid of the whole installation and start again with a new one? I already tried to deinstall Fuerte by
$ sudo apt-get remove ros-fuerte-ros
and reinstalled it but that did not change anything.
EDIT #3
joq, thank you very much for your patience! I'm a total noob...
Unfortunately, I'm still not able to solve the problem. After uninstalling rosdep "which rosdep" answers nothing - not even an error message:
  /usr/local/bin/rosdep-gbp-brew
  /usr/local/bin/rosdep-source
  /usr/local/lib/python2.7/dist-packages/rosdep-0.9.7.egg-info
  /usr/local/lib/python2.7/dist-packages/rosdep2
Proceed (y/n)? y
malte@ubuntu:~$ which rosdep
malte@ubuntu:~$
And the "rosdep" command is not found.
malte@ubuntu:~$ rosdep install turtlesim
rosdep: command not found
That's why I thought I have to reinstall it. Running
I get the message that the newest version of python-rosdep is already installed (the message is in German so I don't post it here).
Any ideas? Thanks again!
EDIT #4
Strange things going on...
malte@ubuntu:~$ dpkg -L python-rosdep
/usr
/usr/bin
/usr/bin/rosdep
/usr/share
/usr/share/python-support
/usr/share/python-support/python-rosdep.public
/usr/share/pyshared
/usr/share/pyshared/rosdep-0.9.7.egg-info
/usr/share/pyshared/rosdep-0.9.7.egg-info/SOURCES.txt
/usr/share/pyshared/rosdep-0.9.7.egg-info/PKG-INFO
/usr/share/pyshared/rosdep-0.9.7.egg-info/requires.txt
/usr/share/pyshared/rosdep-0.9.7.egg-info/dependency_links.txt
/usr/share/pyshared/rosdep-0.9.7.egg-info/top_level.txt
/usr/share/pyshared/rosdep2
/usr/share/pyshared/rosdep2/installers.py
/usr/share/pyshared/rosdep2/dependency_graph.py
/usr/share/pyshared/rosdep2/rospkg_loader.py
/usr/share/pyshared/rosdep2/model.py
/usr/share/pyshared/rosdep2/core.py
/usr/share/pyshared/rosdep2/shell_utils.py
/usr/share/pyshared/rosdep2/rep3.py
/usr/share/pyshared/rosdep2/main.py
/usr/share/pyshared/rosdep2/lookup.py
/usr/share/pyshared/rosdep2/platforms
/usr/share/pyshared/rosdep2/platforms/osx.py
/usr/share/pyshared/rosdep2/platforms/gentoo.py
/usr/share/pyshared/rosdep2/platforms/arch.py
/usr/share/pyshared/rosdep2/platforms/cygwin.py
/usr/share/pyshared/rosdep2/platforms/redhat.py
/usr/share/pyshared/rosdep2/platforms/brewmaker.py
/usr/share/pyshared/rosdep2/platforms/debian.py
/usr/share/pyshared/rosdep2/platforms/opensuse.py
/usr/share/pyshared/rosdep2/platforms/pip.py
/usr/share/pyshared/rosdep2/platforms/freebsd.py
/usr/share/pyshared/rosdep2/platforms/source.py
/usr/share/pyshared/rosdep2/gbpdistro_support.py
/usr/share/pyshared/rosdep2/catkin_support.py
/usr/share/pyshared/rosdep2/loader.py
/usr/share/pyshared/rosdep2/__init__.py
/usr/share/pyshared/rosdep2/sources_list.py
/usr/share/doc
/usr/share/doc/python-rosdep
/usr/share/doc/python-rosdep/changelog.Debian.gz
malte@ubuntu:~$
obviously the list does contain /usr/bin/rosdep. Because "which rosdep" still said nothing I uninstalled and reinstalled python-rosdep again. Now at least "which rosdep" works:
/usr/bin/rosdep
But "rosdep install turtlesim" still doesn't work, the same error as from begin on:
  File "/usr/lib/pymodules/python2.7/rosdep2/main.py", line 111, in rosdep_main
  File "/usr/lib/pymodules/python2.7/rosdep2/main.py", line 232, in _rosdep_main
  File "/usr/lib/pymodules/python2.7/rosdep2/main.py", line 255, in _package_args_handler
  File "/usr/lib/pymodules/python2.7/rosdep2/main.py", line 103, in _get_default_RosdepLookup
  File "/usr/lib/pymodules/python2.7/rosdep2/lookup.py", line 299, in create_from_rospkg
  File "/usr/lib/pymodules/python2.7/rosdep2/lookup.py", line 443, in _load_all_views
  File "/usr/lib/pymodules/python2.7/rosdep2/lookup.py", line 465, in _load_view_dependencies
  File "/usr/lib/pymodules/python2.7/rosdep2/sources_list.py", line 505, in load_view
  File "/usr/lib/pymodules/python2.7/rosdep2/model.py", line 89, in set_view_data
Can I do wrong something very stupid???
To be honest, I would prefer to delete/uninstall as much as possible and start again form scratch. It's getting a little bit frustrating...
EDIT #5
Meanwhile I rebooted the computer several times - no positive effects on the current problem...
EDIT #6
find /usr/local -name rosdep2
Did not find anything
uninstalling and reinstalling python-rosdep did not solve the problem. When running
the same error as before occurred:
I don't want to steel your time. If you do not have any other ideas maybe you can just give me some hints how to get rid of all components installed during the installation of ROS? Is there any way to start a ROS installation from scratch again? I don't care if that would take an hour - solving this problem in a more elegant way will most likely take much longer (at least for me as a beginner)... It would be a little bit ridiculous to make a new Ubuntu installation just to get back to "tabula rasa", wouldn't it? Thanks again for your kind help!
EDIT #7
I uninstalled ROS rebooted the computer and reinstalled ROS following this. Afterwards I again ran through all steps of the tutorial till I reached "Building a ROS package". When typing
the same error as many times before occured:
To sum up: reinstallation did not help at all.
The only little irregularity I experienced during the first steps of the tutorial was that
$ roscd
did not bring me to ~/fuerte_workspace/sandbox (as claimed in the tutorial) but to ~/fuerte_workspace. I don't now why. I moved manually to ~/fuerte_workspace/sandbox and continued the tutorial.
Looks like the chance left for me is to get a new Ubuntu installation... Or has someone any other ideas?
Originally posted by mta on ROS Answers with karma: 41 on 2012-09-02
Post score: 4
Comment by joq on 2012-09-05:
Where does it claim roscd goes to ~/fuerte_workspace/sandbox? This tutorial says (correctly) that it goes to $ROS_WORKSPACE: http://www.ros.org/wiki/ROS/Tutorials/NavigatingTheFilesystem#Special_cases_for_roscd
Comment by mta on 2012-09-05:
I meant "1.2 Creating an new ROS package". Maybe I misunderstood but I interpreted "Now go into the ~/fuerte_workspace/sandbox directory" and "Alternatively, if you use Fuerte or later release, you can simply do: $ roscd" in the sense that both do the same, i.e. bring me to the sandbox directory.
3 Answers 3
Is this the tutorial you are running?
Did you run these commands?
$ sudo rosdep init
$ rosdep update
(Please respond by editing your question.)
UPDATE: you seem to have an old rosdep version installed somewhere. What does this show?
$ which rosdep
If it says something like /usr/local/bin/rosdep, then you need to uninstall the pip or easy_install version you had previously installed. That's simple with pip:
If you used easy_install, you'll have to find and remove all the relevant files by hand.
UPDATE #2: The uninstall was to remove the pip version in /usr/local/bin/rosdep. Then, it will use the correct, up-to-date /usr/bin/rosdep automatically installed via apt-get from the python-rosdep package. After uninstalling, "which rosdep" should show that one.
The pip version is deprecated, because it leads to exactly this kind of problem.
UPDATE #3: somehow your Debian APT database has gotten screwed up. That is not normal. Does the list of files printed here include /usr/bin/rosdep? Does that file exist?
If not, try uninstalling python-rosdep and then reinstalling it again:
$ sudo apt-get remove python-rosdep
UPDATE #4: you are not doing anything wrong, this is just a messy problem. I experienced it, too, when the pip version was replaced by the python-rosdep package.
I think the which command problem was caused by the shell. It keeps a hash table of commands it has found in the search path. When we deleted /usr/local/bin/rosdeps, it got confused.
I have seen this problem with those pyshared files not getting unpacked into /usr/lib/python2.7 properly, but I can't remember exactly how I resolved it.
It might help to reboot.
UPDATE #5: OK, make sure there is no old version anywhere in /usr/local:
$ find /usr/local -name rosdep2
If that finds anything at all, delete it. Then, try reinstalling the scripts again:
UPDATE #6: I have no expectation that uninstalling everything would help. This is not Windows.
But, if you want to try that, this should remove all of ROS (note the single-quote characters):
$ sudo apt-get remove python-rosdep 'ros-fuerte-*'
Originally posted by joq with karma: 25443 on 2012-09-03
Post score: 6
Comment by SivamPillai on 2012-09-04:
one of my friends also got a similar error and we somehow managed to solve it. I think sometimes improper dependency lists for some stacks also cause this issue. I do not remember exactly how the error went away but I'll post if I remember. Am sure I dint do so many things mentioned here.
Hi there,
try this to resolve the problem:
sudo apt-get remove --purge python-rosdep
bash
roscd
sudo rosdep init
sudo rosdep update
Simon
Originally posted by Simon Lynen with karma: 116 on 2012-10-31
There's a lot here so I don't know whether you've got your answer yet or not, but I don't think anyone has said these steps explicitly. The installation requires you to uninstall the pip version if you're running Ubuntu (and trying to install ros-groovy). So follow the installation guide normally up to this step
$ rosdep update
Then if you get the error again after reinstalling Ubuntu (which you said you're doing in your final edit, however that should not affect anything), call:
to remove the pip version, then try again with
$ sudo rm /etc/ros/rosdep/sources.list.d/20-default.list
$ sudo rosdep init
$ rosdep update
Hope that works
