Hello
I'm trying to install ROS Indigo on a NAO V4 with OpenNao 1.14.5.
Following the tutorial "Installation of ROS on the Nao robot" (http://wiki.ros.org/nao/Installation/local) I had an issue starting ROS on NAO:
roslaunch nao_bringup nao.launch
gives me the following output:
File "/opt/openrobots/bin/roslaunch", line 34, in <module>
import roslaunch
File "/var/persistent/opt/openrobots/lib/python2.7/site-packages/roslaunch/__init__.py", line 51, in <module>
from . import param_dump as roslaunch_param_dump
File "/var/persistent/opt/openrobots/lib/python2.7/site-packages/roslaunch/param_dump.py", line 40, in <module>
import roslaunch.config
File "/var/persistent/opt/openrobots/lib/python2.7/site-packages/roslaunch/config.py", line 45, in <module>
import rospkg.distro
File "/var/persistent/opt/openrobots/lib/python2.7/site-packages/rospkg/distro.py", line 44, in <module>
import yaml
ImportError: No module named yaml
I tried to re-install yaml (sudo emerge pyyaml
) and got this error as a result:
ERROR: app-admin/eselect-python-20100321 failed (setup phase):
* GCC >=3.4 is required
* Call stack:
* ebuild.sh, line 75: Called pkg_setup
* environment, line 636: Called die
* The specific snippet of code:
* die "GCC >=3.4 is required";
Therefore has anyone an idea of how to correctly install pyyaml on NAO?
Thank You very much :)
Originally posted by Schwartzmuller on ROS Answers with karma: 1 on 2014-11-06
