Now that catkin is building my service files OK, I can't run it. The relevant code section is:
    rospy.init_node('servo_cmd_server', log_level=rospy.INFO)
    rospy.loginfo("Started Phidgets Servo Command Server Node")
    rospy.sleep(2.0)
    rospy.loginfo("Setting up the command service")
    rospy.loginfo("Namespace: %s", rospy.get_namespace())
    rospy.loginfo("getname:   %s", rospy.get_name())
    rospy.loginfo("Resolved name:   %s", rospy.resolve_name("PhidgetsServoCommand", caller_id="retractor_ros"))
    s = rospy.Service('retractor_cmd', _PhidgetsServoCommand, handle_servo_cmd)
    print 'Ready to receive servo commands!!!.'
    rospy.spin()
And the relevant output is:
[INFO] [WallTime: 1400781040.063425] Namespace: /
[INFO] [WallTime: 1400781040.063572] getname:   /servo_cmd_server
[INFO] [WallTime: 1400781040.063730] Resolved name:   /PhidgetsServoCommand
  File "/home/blake/Projects/Ros/catkin_ws/src/pwm_ros/scripts/pwm_servo.py", line 228, in
    servo_cmd_server()      # start the server (doesn't return)
  File "/home/blake/Projects/Ros/catkin_ws/src/pwm_ros/scripts/pwm_servo.py", line 73, in servo_cmd_server
  File "/opt/ros/hydro/lib/python2.7/dist-packages/rospy/impl/tcpros_service.py", line 696, in __init__
    super(Service, self).__init__(name, service_class, handler, buff_size)
  File "/opt/ros/hydro/lib/python2.7/dist-packages/rospy/impl/tcpros_service.py", line 544, in __init__
    super(ServiceImpl, self).__init__(name, service_class)
  File "/opt/ros/hydro/lib/python2.7/dist-packages/rospy/service.py", line 59, in __init__
    self.request_class = service_class._request_class
AttributeError: 'module' object has no attribute '_request_class'
Any ideas?? BTW, catkin has prefixed the MyName.srv file with an underscore to create _MyName.py . without the underscore, you get:
[INFO] [WallTime: 1400781520.326304] Namespace: /
[INFO] [WallTime: 1400781520.326438] getname:   /servo_cmd_server
[INFO] [WallTime: 1400781520.326581] Resolved name:   /PhidgetsServoCommand
    s = rospy.Service('retractor_cmd', PhidgetsServoCommand, handle_servo_cmd)
NameError: global name 'PhidgetsServoCommand' is not defined
Thanks!
Originally posted by blakeh on ROS Answers with karma: 17 on 2014-05-22
It looks like you still aren't following the tutorial properly.
You should NOT be using the underscore prefixed names; those are internal to the generated module. The normal names ARE defined in the generated __init__.py inside the python srv directory.
This would be easier to troubleshoot if you included your ENTIRE python program, including the import lines.
Originally posted by ahendrix with karma: 47576 on 2014-05-22
Comment by blakeh on 2014-05-28:
Thank you. It seems that different tutorials import differently and not as clearly. Fixing import statement to
#  Ros imports
from retractor_ros.srv import *
import rospy
(and avoiding the underscores) Seemed to do the trick.
Comment by ahendrix on 2014-05-28:
If the tutorials are incorrect, you should either update the wiki to fix them, post them here so that another user can take a look, or contact the author if they're not hosted on the ROS wiki.
Actually above is wrong. somehow that line is now an error!
Latest output
blake@blake-Lenovo-IdeaPad-U530-Touch:~/Projects/Ros/catkin_ws$ source devel/setup.bash
blake@blake-Lenovo-IdeaPad-U530-Touch:~/Projects/Ros/catkin_ws$ rossrv
list      md5       package   packages  show
blake@blake-Lenovo-IdeaPad-U530-Touch:~/Projects/Ros/catkin_ws$ rossrv show retractor_ros/PhidgetsServoCommand
int64 servo
float64 displacement
int64 return_flag
blake@blake-Lenovo-IdeaPad-U530-Touch:~/Projects/Ros/catkin_ws$ rosrun retractor_ros pwm_servo.py
  File "/home/blake/Projects/Ros/catkin_ws/src/pwm_ros/scripts/pwm_servo.py", line 23, in <module>
    from PhidgetsServoCommand.srv import *
ImportError: No module named PhidgetsServoCommand.srv
The appropriate import is:
or
from retractor_ros.srv import PhidgetsServoCommand
In general, the syntax is:
from [package].srv import [service]
Aha! that worked. thanks for your persistence.
