How can I use pypy instead of the default python interpreter for a ROS node written in python ? I tried:
cd /path/to/node
pypy script/pioneer.py
But I'm getting an error:
  File "app_main.py", line 51, in run_toplevel
  File "scripts/pioneer.py", line 5, in
    import roslib
  File "/opt/ros/groovy/lib/python2.7/dist-packages/roslib/__init__.py", line 50, in
    from roslib.launcher import load_manifest
  File "/opt/ros/groovy/lib/python2.7/dist-packages/roslib/launcher.py", line 42, in
    import rospkg
ImportError: No module named rospkg
Also, changing the first line of the script to #!/usr/bin/pypy and using rosrun yields the same.
EDIT: OK, I added the missing directories to sys.path (namely /usr/lib/pymodules/python2.7) but now I'm getting another error:
ImportError: No module named _tf
Originally posted by victorp on ROS Answers with karma: 50 on 2013-06-26
tf uses c binding for python which are going to be harder in pypy.
Originally posted by tfoote with karma: 58457 on 2013-08-12
Comment by gre721 on 2016-12-19:
Could you solve to use pypy with ROS?
Thank you!
Comment by ahendrix on 2016-12-19:
No; as @tfoote said this would require a significant rewrite of tf (and probably other libraries that use the cpython API).
