So, I am trying to make ROS run on the NAO. I have followed the wiki for Nao-Cross-Compiling, and I get everything to show up on the robot as stated in the wiki. However, when I go to run roscore, just to see if it will work, I get the following error message:
File "/media/external/ros/electric/ros/bin/roscore", line 34, in from ros import roslaunch File "/media/external/ros/electric/ros/core/roslib/src/ros/init.py", line 57, in getattr return import(name) File "/media/external/ros/electric/ros_comm/tools/roslaunch/src/roslaunch/init.py", line 43, in import roslaunch.param_dump File "/media/external/ros/electric/ros_comm/tools/roslaunch/src/roslaunch/param_dump.py", line 43, in import yaml ImportError: No module named yaml
The PYTHONPATH for my setup.sh file looks like this:
PYTHONPATH=/media/external/python:/media/external/ros/electric/ros/core/roslib/src:$PYTHONPATH
The /media/external/python folder contains the yaml folder.
Any suggestions are greatly appreciated.
[edit] OS is Ubuntu 10.04 and nao sdk and toolchain are 1.10.44
Originally posted by dougnets22 on ROS Answers with karma: 61 on 2012-02-02
You're likely missing the python-yaml package on your system. It's a core system dependency when installing from source instructions
Originally posted by tfoote with karma: 58457 on 2012-02-02
Comment by dougnets22 on 2012-02-05:
Whenever I run the setup: sudo apt-get install build-essential python-yaml cmake subversion wget python-setuptools mercurial git-core, it tells me that pyton-yamal is already the newest version
