Hello all, I am running a python script from a callback. When I run my test code from my shell, I have my environment variables (from my bashrc), more specifically my PYTHONPATH. However, when I do a roslaunch, PYTHONPATH is only pointing to the ros python modules. Could anyone offer any suggestions? Do I need to use the tags in the launch file? Is roslaunch overwriting environment variables or is it running in a different shell? Thank you
Constantin
Edit: I am getting this runtime error as well. If you notice, there is a missing symbol _Py_ZeroStruct. I have seen similar error messages and they've always been related to me not linking a library correctly. In this case it seems the python library may not be linking correctly. In my example program, I simply use:
 -lpython2.6
In the CMakeList.txt, I use:
 target_link_libraries(ExtractionController python2.6)
I have a feeling, ROS is forcing a bad link somewhere though. Has anyone experienced this? Thank you. Here is a print out of the runtime error:
  File "/usr/lib/python2.6/dist-packages/numpy/__init__.py", line 130, in
    import add_newdocs
  File "/usr/lib/python2.6/dist-packages/numpy/add_newdocs.py", line 9, in
    from lib import add_newdoc
  File "/usr/lib/python2.6/dist-packages/numpy/lib/__init__.py", line 4, in
    from type_check import *
  File "/usr/lib/python2.6/dist-packages/numpy/lib/type_check.py", line 8, in
    import numpy.core.numeric as _nx
  File "/usr/lib/python2.6/dist-packages/numpy/core/__init__.py", line 5, in
    import multiarray
ImportError: /usr/lib/python2.6/dist-packages/numpy/core/multiarray.so: undefined symbol: _Py_ZeroStruct
  File "/home/constantin/workspace/OpenRAVE/src/grasp_behavior_2.py", line 3, in
    from openravepy import *
  File "/home/constantin/workspace/rospackages/openrave/lib/python2.6/site-packages/openravepy/__init__.py", line 35, in
    openravepy_currentversion = loadlatest()
  File "/home/constantin/workspace/rospackages/openrave/lib/python2.6/site-packages/openravepy/__init__.py", line 16, in loadlatest
    return _loadversion('_openravepy_')
  File "/home/constantin/workspace/rospackages/openrave/lib/python2.6/site-packages/openravepy/__init__.py", line 19, in _loadversion
    mainpackage = __import__("openravepy", globals(), locals(), [targetname])
  File "/home/constantin/workspace/rospackages/openrave/lib/python2.6/site-packages/openravepy/_openravepy_/__init__.py", line 29, in
    from openravepy_int import *
ImportError: numpy.core.multiarray failed to import
Originally posted by Constantin S on ROS Answers with karma: 296 on 2011-11-28
I have managed to find a solution for my first problem. Using the following code inside a launch file allows me to pass in my PYTHONPATH. I am assuming this will work for all other environment variables that are being lost as well:
<env name="PYTHONPATH" value="$(env PYTHONPATH)" />
I hope this helps.
Originally posted by Constantin S with karma: 296 on 2011-11-28
