Hi,
I'm using diamondback and rviz has segmentation faults often whenever I kill another node.
Should I expect this whenever stopping a node that was publishing a topic that rviz is subscribed to?
E.g.: I run roscore in one terminal, openni_camera openni_node.launch, and rviz from another terminal. I can view the /camera/rgb/points topic in rviz fine. However, if I stop the openni_node.launch, rviz segfaults.
Is there anything I can do to change the rosrun / roslaunch settings to prevent this? It would be helpful to not have to restart rviz everytime I want to stop a node to debug something.
Thanks.
Originally posted by elsey on ROS Answers with karma: 76 on 2011-03-24
Comment by Eric Perko on 2011-03-24:
Could you make sure to include which version of Ubuntu you are running on and what video drivers? There is a known bug with certain versions of Nvidia drivers on 10.10 that causes anything linked against OpenGL to crash. See https://code.ros.org/lurker/message/20110204.151901.a4e1d645.en.html .
Thanks, Eric, for pointing out the thread on the drivers issue.
I upgraded drivers from NVIDIA 260.19.06 to NVIDIA 260.19.44, and that solved the issue.
Originally posted by elsey with karma: 76 on 2011-03-24
Comment by fergs on 2011-04-02:
I can confirm that the launchpad approach also works to fix this issue.
Comment by elsey on 2011-03-30:
I updated by downloading and installing the driver from the Nvidia website: http://www.nvidia.com/Download/index.aspx?lang=en-us . Someone also pointed me to https://launchpad.net/~ubuntu-x-swat/+archive/x-updates as an alternative to installing from the website, but I haven't tried it myself.
Comment by aleeper on 2011-03-29:
Can you explain how you updated the Nvidia driver to 260.19.44? Did you download it from their site, or update something that made Ubuntu pull in the newest driver?
