I came across a segmentation fault while trying rosrun rviz rviz. This issue has been discussed on this web( http://answers.ros.org/question/11376/rviz-segmentation-fault-at-launch/ ), but I think that essential issue has been not solved. The solution in the comment and the answer was to delete all of file in ~/.rviz. I also deleted all of files as I follow the instruction. But, the error doesn't go out.
[ INFO]rviz version 1.10.14
[ INFO]compiled against OGRE version 1.7.4 (Cthugha)
[ INFO]Stereo is NOT SUPPORTED
[ INFO]OpenGl version: 2.1 (GLSL 1.2)
Segmentation fault
I have checked the article (http://wiki.ros.org/rviz/Troubleshooting). I can't find the way to solve the issue on the article. Could anyone give me clues? Thank you in advance!
Originally posted by Ken_in_JAPAN on ROS Answers with karma: 894 on 2014-04-08
The type of graphics card you use always is crucial when looking at rviz crashes (you can edit your answer to add that information). The rule of thumb is: "Nvdidia GPUs with propietary drivers generally work well, others might crash occasionally (or always in a absolute worst case)". With your GPU and driver known, I´d recommend googling something like "rviz crashes ros answers [your graphics card type]". There are tons of posts on rviz crashes on ROS Answers and it´s likely that there will be useful information in some of them.
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2014-04-08
Comment by Ken_in_JAPAN on 2014-04-08:
@Stefan Kohlbrecher: Thank you for your advice! I will check it out tomorrow. Sorry, here is at midnight.
@Stefan Kohlbrecher: I was looking over the article on the web(http://wiki.ros.org/rviz/Tutorials/Rviz%20in%20Stereo). Do you think that this contents connects with my issues?
Comment by Stefan Kohlbrecher on 2014-04-08:
Unless you try something with stereo mode, no. I assume you installed from .deb packages?
Comment by Ken_in_JAPAN on 2014-04-09:
I don't make sense, I was googling to search for the cause and how to fix it. I also tried the method on the web (https://github.com/ros-visualization/rviz/issues/713), but segmentation fault didn't go out. I will reinstall.
Hi all,
I spent a load of time fixing these issues. What I realised is that Virtualbox is being a nasty little rascal with it's 3d Acceleration.
Switching if off fixed these issues for me.
Switch off your VM Just go to the VM Settings -> Display -> Uncheck Enable 3D Acceleration. Start your VM again. Rejoice!
Originally posted by sachitv with karma: 51 on 2017-04-16
Comment by iguanaistic on 2017-04-21:
Thank you! This worked for me.
