I don't get any data (rgb image,depth image,rviz) from the kinect,I'm running on Ubuntu 10.10 ,diamondback;basically what I did is :
  1. I set up my computer to accept software from ROS.org
  2. I ran roscore on a new terminal by typing : roscore
3)I installed openNI kinect by typing : sudo apt-get install ros-diamondback-openni-kinect
4)I installed openNi camera by typing : rosmake openni_camera
5)I launched the openNI driver by typing :roslaunch openni_camera openni_node.launch
6)I ran rviz by typing: rosrun rviz rviz
7)I ran the rgb camera by typing : rosrun image_view image_view image:=/camera/rgb/image_color
please help me fix it.
Originally posted by bassim on ROS Answers with karma: 1 on 2011-10-25
Comment by bassim on 2011-11-04:
I got them from ROS.org ,if you think that they are wrong,could you please tell me what are the right instructions ?
Comment by tfoote on 2011-10-25:
Where did you get these instructions from? These are not the standard wa to install the kinect drivers.
If you would like to view images coming from the kinect camera, follow the instructions posted here: http://www.ros.org/wiki/openni_kinect and here: http://www.ros.org/wiki/openni_camera
which are summarized as follows:
  1. install openni_kinect: sudo apt-get install ros-electric-openni-kinect
  2. run openni: roslaunch openni_launch openni.launch
  3. run image viewer: rosrun image_view image_view image:=/camera/rgb/image_color
This video tutorial for the TurtleBot might also be helpful: http://www.ros.org/wiki/turtlebot/Tutorials/Looking%20at%20Camera%20Data
Originally posted by mmwise with karma: 8372 on 2011-10-25
Comment by mmwise on 2011-11-07:
you should see a line like this in the output ... [ INFO] [1320711146.846538470]: Number devices connected: 1
can you copy and paste the output from that terminal into your question
Comment by bassim on 2011-11-07:
no , I didnt get any error !
Comment by mmwise on 2011-11-04:
are there any errors in the terminal where you called roslaunch openni_camera openni_node.launch?
when I typed on a new terminal : rostopic hz/camera/rgb/image_color . I got this : WARNING: topic [/camera/rgb/image_color] does not appear to be published yet
@bassim do you see any errors in the terminal when you roslaunch openni_camera openni_node.launch .. can you rostopic hz /camera/rgb/image_color
Comment by mmwise on 2011-11-02:
@bassim what happens when you follow these instructions. do you see any console output? Any error messages? You need to provide more information so that we can help you
First, pasting half of the web into your question doesn't help.
What's this KinectROSPackage thing you're talking about? You should just install openni_kinect from the binaries:
and then use the various nodes it provides.
Originally posted by Mac with karma: 4119 on 2011-10-25
