Hi All,
I have reciently upgraded from Fuerte to Groovy, and I am working on Ubuntu Precise.
I wanted to start simulating my robot in Gazebo using my existing URDF and models. I started by trying out Gazebo with the debian package ros-groovy-simulator-gazebo by running
kel@accuser:~$ rosrun gazebo gazebo
This gives the following behavior, similar to this question posted to answers.gazebosim.org.
Gazebo multi-robot simulator, version 1.3.0
Copyright (C) 2012 Nate Koenig, John Hsu, and contributors.
Released under the Apache 2 License.
http://gazebosim.org
Msg Waiting for master.[ INFO] [1363287175.831594707]: waitForService: Service [/gazebo /set_physics_properties] has not been advertised,
waiting.................
Which then continues to wait forever, and has to be ctrl-\ to be stopped (or killed).
At first I thought that this could be a problem with my ROS_IP or other network parameters, but I think those are ok, and other ROS nodes can be brought up just fine:
kel@accuser:~$ export |grep ROS
returns
declare -x ROS_DISTRO="groovy"
declare -x ROS_ETC_DIR="/opt/ros/groovy/etc/ros"
declare -x ROS_IP="10.162.34.26"
declare -x ROS_MASTER_URI="http://localhost:11311"
declare -x ROS_PACKAGE_PATH="/home/kel/ros_workspace/executive_smach_tutorials:/home/kel /ros_workspace/adjutant:/home/kel/ros_workspace/merlin_robot:/home/kel/ros_workspace /ros_controllers:/home/kel/ros_workspace/ros_control:/opt/ros/groovy/share:/opt/ros/groovy/stacks"
declare -x ROS_ROOT="/opt/ros/groovy/share/ros"
declare -x ROS_WORKSPACE="/home/kel/ros_workspace"
and
kel@accuser:~$ ifconfig
returns
eth0 Link encap:Ethernet HWaddr 00:1a:6b:36:b0:1b
inet addr:10.162.34.26 Bcast:10.162.34.255 Mask:255.255.255.0
inet6 addr: fe80::21a:6bff:fe36:b01b/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1425950 errors:0 dropped:0 overruns:0 frame:0
TX packets:477752 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:212769407 (212.7 MB) TX bytes:39867099 (39.8 MB)
Interrupt:20 Memory:fe200000-fe220000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:111011 errors:0 dropped:0 overruns:0 frame:0
TX packets:111011 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:15710426 (15.7 MB) TX bytes:15710426 (15.7 MB)
After reading a few other questions such as this one, it seems apparent that the ROS simulator-gazebo stuff is deprecated. However, I have it on good authority that the ros simulator-gazebo tools (specifically the spawn_model command to use URDF's) should still work as of Groovy.
I am not sure if the error I am having with simulator-gazebo is related to a separate problem, or this supposed deprecation. I also have installed Gazebo 1.5. What is the best way for me to use my existing URDFs and models?
Thanks for the help, and let me know if you need more information about anything.
Cheers, Kel Guerin
Johns Hopkins University
Originally posted by KelGuerin on Gazebo Answers with karma: 16 on 2013-03-14
