Gazebo Answers logo
Hi,
I am using ROS Groovy and I updated Gazebo to 1.3 (binary version), under Ubuntu 12.04.
For testing it I got a simple empty.world:
<?xml version ='1.0'?>
<sdf version ='1.3'>
  <world name='default'>
    <include>
      <uri>model://ground_plane</uri>
    </include>
    <include>
      <uri>model://sun</uri>
    </include>
  </world>
</sdf>
After I source:
/opt/ros/groovy/stacks/simulator_gazebo/gazebo/gazebo/share/gazebo-1.3/setup.sh /opt/ros/groovy/stacks/simulator_gazebo/gazebo/setup.bash
and run gzserver:
rosrun gazebo gzserver ~/../worlds/empty.world
I got the following error msg:
Error [RenderEngine.cc:374] Unable to load Ogre Plugin[/opt/ros/groovy/stacks/visualization_common/ogre/ogre/lib/OGRE/RenderSystem_GL]. Rendering will not be possible.Make sure you have installed OGRE and Gazebo properly.
Error [Rendering.cc:37] Failed to load the Rendering engine subsystem
unable to find OpenGL rendering system. OGRE is probably installed incorrectly. Double check the OGRE cmake output, and make sure OpenGL is enabled.
Did something happen to the OpenGL libraries during the update, or is this a bug?
Thanks, Andrei
Originally posted by AndreiHaidu on Gazebo Answers with karma: 2108 on 2013-01-30
3 Answers 3
Gazebo Answers logo
Hi, Andrei
I had the same error too. I have found that OGRE_RESOURCE_PATH was not correct. There was a row
export OGRE_RESOURCE_PATH=/usr/lib/x86_64-linux-gnu/OGRE-1.7.4
in file /opt/ros/groovy/stacks/simulator_gazebo/gazebo/scripts/setup.sh However, folder [x86_64-linux-gnu] is empty on my computer. I have found OGRE-1.7.4 in folder [/usr/lib/i386-linux-gnu], so I replace the row on following row:
export OGRE_RESOURCE_PATH=/usr/lib/i386-linux-gnu/OGRE-1.7.4
Now I have not this error.
Best Regards, Alex
Originally posted by Alex Buyval with karma: 31 on 2013-02-02
Comment by AndreiHaidu on 2013-02-05:
Hi Alex, thanks for answering, for me the solution it doesn't work. I actually have the libraries in x86_64-linux-gnu/OGRE-1.7.4. I will try a reinstall.
I figured it out thanks to your answer, I had a different path in the setup.sh, which changed with the update. And I guess you had to change it to i386-linux-gnu because you are running on 32 bits.
Comment by destogl on 2013-04-08:
Thanks! Works for 32 bit 12.04 Ubuntu
Gazebo Answers logo
Solution: in
/opt/ros/groovy/stacks/simulator_gazebo/gazeb/setup.bash
I had to change the OGRE_RESOURCE_PATH to:
UPDATE: according to @Ryan:
on Ubuntu 11.10, change OGRE_RESOURCE_PATH to /usr/lib/OGRE in both
and
Originally posted by AndreiHaidu with karma: 2108 on 2013-02-05
Gazebo Answers logo
I'm on Ubuntu 11.10 at the moment. I needed to change OGRE_RESOURCE_PATH to /usr/lib/OGRE in both
and
Comment by ZdenekM on 2013-05-14:
Thanks, it helped.
