Hi all, I want to run the simulation http://www.ros.org/wiki/simulator_gazebo/Tutorials/StartingGazebo,but it gives me error message as follows. seems it is a GUI rendering problem? Is it related to graphic drivers? I am using a Lenovo t410 notebook with Ubuntu 10.04.
The gazebo-2 process died but the log file is empty. The exit code sometimes will be 255.
/tmp/buildd/ros-cturtle-simulator-gazebo-1.2.8/debian/ros-cturtle-simulator-gazebo/opt/ros/cturtle/stacks/simulator_gazebo/gazebo/build/gazebo/server/rendering/OgreCreator.cc:441 : Exception: Unable to create the rendering window
/tmp/buildd/ros-cturtle-simulator-gazebo-1.2.8/debian/ros-cturtle-simulator-gazebo/opt/ros/cturtle/stacks/simulator_gazebo/gazebo/build/gazebo/server/Simulator.cc:261 : Exception: Error loading the GUI /tmp/buildd/ros-cturtle-simulator-gazebo-1.2.8/debian/ros-cturtle-simulator-gazebo/opt/ros/cturtle/stacks/simulator_gazebo/gazebo/build/gazebo/server/rendering/OgreCreator.cc:441 : Exception: Unable to create the rendering window
Error Loading Gazebo /tmp/buildd/ros-cturtle-simulator-gazebo-1.2.8/debian/ros-cturtle-simulator-gazebo/opt/ros/cturtle/stacks/simulator_gazebo/gazebo/build/gazebo/server/Simulator.cc:261 : Exception: Error loading the GUI /tmp/buildd/ros-cturtle-simulator-gazebo-1.2.8/debian/ros-cturtle-simulator-gazebo/opt/ros/cturtle/stacks/simulator_gazebo/gazebo/build/gazebo/server/rendering/OgreCreator.cc:441 : Exception: Unable to create the rendering window
[gazebo-2] process has died [pid 25662, exit code -11]. log files: /home/btian/.ros/log/d469a558-376d-11e1-bcb0-f0def113b3f6/gazebo-2*.log
Originally posted by tianb03 on ROS Answers with karma: 710 on 2012-01-04
Comment by Arkapravo on 2012-01-04:
@tianb03 : Hi, can you check your /tmp folder for a gazebo folder. Try deleting it and then running the simulation.
You can see this question for some information regarding graphics drivers. Additionally, many Lenovo computers come with Optimus (two graphics cards). This does not play well with Ubuntu. Consider disabling one card.
Originally posted by DimitriProsser with karma: 11163 on 2012-01-05
Comment by tianb03 on 2012-05-24:
thanks. I am away for quite a while. but this does help me.
