Gazebo Answers logo
Hello All, I recently learned that URDF is being deprecated, being substituted by SDF. I have in the past used spawn_models node to introduce new models in my Gazebo environment. How do I spawn SDF models? I tried using the 'Open' option in the Gazebo world GUI but it gives me the following error:
Error [parser.cc:566] XML Element[static], child of element[model] not defined in SDF. Ignoring.[model] Error [parser.cc:557] Error reading element Error [parser.cc:340] Unable to parse sdf element[gazebo] Error [parser.cc:263] parse as old deprecated model file failed. Error [Server.cc:396] Unable to read sdf file[/opt/ros/fuerte/stacks/simulator_gazebo/gazebo_worlds/objects/first_robotv3.sdf]
The SDF file I am trying to load is exactly from the tutorials found here: http://gazebosim.org/wiki/Tutorials/1.2/build_robot/mobile_base
This should work with ROS as well right?
Please help. Thanks, Ammar
EDIT: So after trying a few different configurations I observed that ROS has a gazebo node and a gazebo-1.0.2 node. Which one of these two supports SDF better? The default launch files I found in the simulator_gazebo stack were launching the "gazebo" node. When I try to launch the "gazebo-1.02" node I get the following error: Error [SystemPaths.cc:262] cannot load file [sdf/gazebo.sdf]in GAZEBO_RESOURCE_PATH
I am really confused with which is a stable Gazebo version I should use. Thanks
Originally posted by ammar on Gazebo Answers with karma: 11 on 2012-11-06
Gazebo Answers logo
Hello,
You can programmatically spawn an SDF model a couple ways:
  1. Via a World or Model plugin:
  1. Via a msgs::Factory message on the "~/factory" topic.
  2. Use the gzfactory command line tool.
Originally posted by nkoenig with karma: 7676 on 2012-11-06
Comment by mcevoy.andy on 2012-11-06:
is this only for v1.2? I get errors when trying to insert by the last two methods in point 1. I followed the tutorial for v1.0. error = class gazebo::physics::World’ has no member named ‘InsertModelSDF’ and same thing for 'InsertModelString'
Comment by ammar on 2012-11-06:
I get errors in the last method as well: Error [SystemPaths.cc:262] cannot load file [sdf/gazebo.sdf]in GAZEBO_RESOURCE_PATH[/opt/ros/fuerte/stacks/simulator_gazebo/gazebo:] ERROR: SDF parsing the xml failed
Comment by nkoenig on 2012-11-07:
This is only for gazebo 1.2 and greater.
Comment by ammar on 2012-11-08:
Is there a gazebo 1.2 plugin for ROS?
Comment by nkoenig on 2012-11-09:
It is being worked on as we speak.
Comment by Ben B on 2013-01-14:
These links all take me to the Gazebosim home page.
Comment by SL Remy on 2016-02-15:
Unfortunately the links in this answer have gone stale.
