Hi everyone,
I am trying to make a URDF model and view it in Rviz. However, when I try to display the URDF model with RVIZ, it just spits out the following error:
[ERROR] [1586312501.638016618]: Could not parse visual element for Link [fl_module_base]
[ERROR] [1586312501.638561453]: Could not parse visual element for Link [base]
[ERROR] [1586312502.490229106]: Could not parse visual element for Link [fl_module_base]
[ERROR] [1586312502.490260233]: Could not parse visual element for Link [base]
Although the URDF is generated through a XACRO, I tried changing the .urdf file directly, with the same issue. It seems like the error is thrown just for the visual tag being where it is. Does anyone know what I might be doing wrong? Or is this just a bug? The URDF I am using is also below:
Cheers!
<?xml version="1.0" encoding="utf-8"?>
<!-- | This document was autogenerated by xacro from base.urdf.xacro | -->
<!-- | EDITING THIS FILE BY HAND IS NOT RECOMMENDED | -->
<robot name="base">
<link name="fl_module_base">
<visual>
<cylinder length="0.6" radius="0.2"/>
</visual>
</link>
<link name="base">
<visual>
<cylinder length="0.2" radius="0.2"/>
</visual>
</link>
<joint name="base_joint" type="fixed">
<parent link="base"/>
<child link="fl_module_base"/>
<origin rpy="0.0 0.0 0.0" xyz="0.0 0.0 0.0"/>
</joint>
</robot>
Originally posted by alextac98 on ROS Answers with karma: 113 on 2020-04-07
