Hi can someone help me with this error?
lucas@lucas-VirtualBox:~$ source /home/lucas/projects/imagine/build/devel/setup.bash
lucas@lucas-VirtualBox:~$ rviz
[ INFO] [1547197031.245982719]: rviz version 1.12.16
[ INFO] [1547197031.246442344]: compiled against Qt version 5.5.1
[ INFO] [1547197031.246692910]: compiled against OGRE version 1.9.0 (Ghadamon)
[ INFO] [1547197031.735517498]: Stereo is NOT SUPPORTED
[ INFO] [1547197031.736545820]: OpenGl version: 3 (GLSL 1.3).
[ERROR] [1547197038.107183504]: PluginlibFactory: The plugin for class 'grid_map_rviz_plugin/GridMap' failed to load.  Error: Could not find library corresponding to plugin grid_map_rviz_plugin/GridMap. Make sure the plugin description XML file has the correct name of the library and that the library actually exists.
Originally posted by LucLucLuc on ROS Answers with karma: 3 on 2019-01-11
Comment by gvdhoorn on 2019-01-11:
Not without a verbatim copy-paste of the full error.
Comment by LucLucLuc on 2019-01-11:
i want to include a image. But it doesnt work. I dont now why. It shows ">5 points required to upload files" I try wih Chrom/ Internet Explorer - jpg/png/ and pdf ---- do you have any idea?
There is absolutely no need for attaching images. Error messages are text and can be copy-pasted, verbatim, from the terminal window into your question. Please do so.
thanks for your fast answers. I followed your advice
Have you actually installed the wiki/grid_map_rviz_plugin package?
Edit: and seeing this:
can you tell us how you've setup your workspace?
Originally posted by gvdhoorn with karma: 86574 on 2019-01-11
Oh nice, i actually installed the wiki/grid_map_rviz_plugin package - it works. But i want to creat a package independent project in c++..
Why do I have to install the package? Why can not cmake with catkin contain the necessary files?
Comment by gvdhoorn on 2019-01-11:\
I don't understand what that means, but how do you expect things to work without having the plugin actually installed?
CMake ~= Catkin are build tools. They don't contain any code other than what is needed to be able to build software.
You're sort-of asking: "why does Visual Studio not contain/provide MS Word?"
