Hello,
I have heavy problems with developing own panel i rviz. I have prepared everything, it compiles without warning but while loading, the rviz writes
PluginlibFactory: The plugin for class 'assistant_panel/Widget_interface' failed to load. Error: Failed to load library /home/xxx/ws/ws_linux/devel/lib/libassistant_panel.so. Make sure that you are calling the PLUGINLIB_EXPORT_CLASS macro in the library code, and that names are consistent between this macro and your XML. Error string: Could not load library (Poco exception = /home/xxx/ws/ws_linux/devel/lib/libassistant_panel.so: undefined symbol: _ZTVN15assistant_panel16Widget_interfaceE)
Eveyrthing looks ok, but I am trying to solve it for last two days but I am failing.
link for the soft: https://drive.google.com/file/d/0B5_3aKfZ-sqNVHpQQ3o3YkV0S0k/view?usp=sharing
Files:
CMakeLists.txt
# CMake
cmake_minimum_required(VERSION 2.8.0)
project(assistant_panel)
# Catkin
# qt_build provides the qt cmake glue, roscpp the comms for a default talker
find_package(catkin REQUIRED COMPONENTS qt_build roscpp rviz)
include_directories(${catkin_INCLUDE_DIRS})
# Use this to define what the package will export (e.g. libs, headers).
# Since the default here is to produce only a binary, we don't worry about
# exporting anything.
catkin_package()
# Qt Environment
# this comes from qt_build's qt-ros.cmake which is automatically
# included via the dependency call in package.xml
rosbuild_prepare_qt4(QtCore QtGui) # Add the appropriate components to the component list here
# Sections
file(GLOB QT_FORMS RELATIVE ${CMAKE_CURRENT_SOURCE_DIR} ui/*.ui)
file(GLOB QT_RESOURCES RELATIVE ${CMAKE_CURRENT_SOURCE_DIR} resources/*.qrc)
file(GLOB_RECURSE QT_MOC RELATIVE ${CMAKE_CURRENT_SOURCE_DIR} FOLLOW_SYMLINKS include/assistant_panel/*.hpp)
QT4_ADD_RESOURCES(QT_RESOURCES_CPP ${QT_RESOURCES})
QT4_WRAP_UI(QT_FORMS_HPP ${QT_FORMS})
QT4_WRAP_CPP(QT_MOC_HPP ${QT_MOC})
# Sources
file(GLOB_RECURSE QT_SOURCES RELATIVE ${CMAKE_CURRENT_SOURCE_DIR} FOLLOW_SYMLINKS src/*.cpp)
# Binaries
#add_executable(assistant_panel ${QT_SOURCES} ${QT_RESOURCES_CPP} ${QT_FORMS_HPP} ${QT_MOC_HPP}  ${QT_MOC})
add_library(${PROJECT_NAME} ${QT_SOURCES} ${QT_RESOURCES_CPP} ${QT_MOC})
target_link_libraries(assistant_panel ${QT_LIBRARIES} ${catkin_LIBRARIES})
#install(TARGETS assistant_panel RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION})
install(TARGETS
  ${PROJECT_NAME}
  ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
  LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
install(FILES
  plugin_description.xml
  DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION})
install(DIRECTORY media/
  DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}/media)
install(DIRECTORY icons/
  DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}/icons)
install(PROGRAMS scripts/send_test_msgs.py
Package.xml
<package>
  <name>assistant_panel</name>
  <version>0.1.0</version>
  <description>
     assistant_panel
  </description>
  <maintainer email="[email protected]">ReMeDi</maintainer>
  <author>ReMeDi</author>
  <license>BSD</license>
  <!-- <url type="bugtracker">https://github.com/stonier/qt_ros/issues</url> -->
  <!-- <url type="repository">https://github.com/stonier/qt_ros</url> -->
  <buildtool_depend>catkin</buildtool_depend>
  <build_depend>qt_build</build_depend>
  <build_depend>roscpp</build_depend>
  <build_depend>libqt4-dev</build_depend>
  <build_depend>rviz</build_depend>
  <run_depend>rviz</run_depend>
  <run_depend>qt_build</run_depend>
  <run_depend>roscpp</run_depend>
  <run_depend>libqt4-dev</run_depend>
  <export>
      <rosdoc config="${prefix}/rosdoc.yaml"/>
      <rviz plugin="${prefix}/plugin_description.xml"/>
  </export>
</package>
<library path="libassistant_panel">
  <class name="assistant_panel/Widget_interface"
         type="assistant_panel::Widget_interface"
         base_class_type="rviz::Panel">
    <description>
      sddfsrfrfvg.
    </description>
  </class>
</library>
main_window.hpp
 * @file /include/assistant_panel/main_window.hpp
 * @brief Qt based gui for assistant_panel.
 * @date November 2010
#ifndef assistant_panel_MAIN_WINDOW_H
#define assistant_panel_MAIN_WINDOW_H
** Includes
//#include <QtGui/QWidget_interface>
#include "ui_main_window.h"
#include "qnode.hpp"
#include <ros/ros.h>
#include <geometry_msgs/Twist.h>
#include <rviz/panel.h>
** Namespace
namespace assistant_panel {
** Interface [Widget_interface]
 * @brief Qt central, all operations relating to the view part here.
class Widget_interface : public rviz::Panel {
Q_OBJECT
public:
   // Widget_interface();
    Widget_interface(QWidget *parent = 0);
    ~Widget_interface();
public Q_SLOTS:
    ** Auto-connections (connectSlotsByName())
    ** Manual connections
private:
    Ui::Widget_interface ui;
    //QNode qnode;
}  // namespace assistant_panel
#endif // assistant_panel_MAIN_WINDOW_H
main_window.cpp
 * @file /src/main_window.cpp
 * @brief Implementation for the qt gui.
 * @date February 2011
** Includes
#include <QtGui>
#include <QMessageBox>
#include <iostream>
#include "../include/assistant_panel/main_window.hpp"
** Namespaces
//using namespace Qt;
** Implementation [Widget_interface]
Widget_interface::Widget_interface(QWidget *parent)
    : rviz::Panel(parent)
    ui.setupUi(this); // Calling this incidentally connects all ui's triggers to on_...() callbacks in this class.
    setWindowIcon(QIcon(":/images/icon.png"));
#include <pluginlib/class_list_macros.h>
PLUGINLIB_EXPORT_CLASS(assistant_panel::Widget_interface, rviz::Panel)
CMakeLists.txt
# CMake
# Catkin
catkin_package()
# Qt Environment
# Sections
# Sources
# Binaries
install(TARGETS
  ${PROJECT_NAME}
install(FILES
Package.xml
<package>
  <description>
     assistant_panel
  </description>
  <export>
  </export>
</package>
    <description>
      sddfsrfrfvg.
    </description>
  </class>
</library>
main_window.hpp
** Includes
** Namespace
Q_OBJECT
public:
public Q_SLOTS:
private:
    //QNode qnode;
main_window.cpp
** Includes
#include <QtGui>
#include <iostream>
** Namespaces
Originally posted by mcholewi on ROS Answers with karma: 41 on 2015-08-09
Post score: 4
Comment by William on 2015-08-10:
This usually happens when you're loading a version of the plugin from a different, overlayed workspace. Make sure you've source'd any setup.bash from your latest workspace before running rviz.
Comment by mcholewi on 2015-08-12:
Yes, I am loading. As I have written below the rviz want the symbol, which is actually Undefined. Well, it is very strange, because I have panel which works perfectly. The only difference is not using the ui_ generated header and slightly different CMakeLists. I`ve checked that it is no CMakLists
I encountered similar question when using pluginlib for loading my customized rviz panel, but I was using CMAKE_AUTOMOC for my qt objects. (Working on Ubuntu 14.04, ROS indigo)
My file system structure is like this:
pkg_folder
\-  config
\-  include/rviz_panel.h
\-  src/rviz_panel.cpp
\-  CMakeLists.txt
\-  package.xml
\-  package_description.xml
The core parts for add_library is:
catkin_package()
include_directories(include)
set(CMAKE_AUTOMOC ON)
set(HEADER_FILES
   include/FrameFabRvizPanel.h
set(SRC_FILES
    src/FrameFabRvizPanel.cpp
    #src/FrameFab.cpp
    #src/FrameFabRenderWidget.cpp
    #src/WireFrame.cpp
**add_library(${PROJECT_NAME} ${SRC_FILES})**
    ${PROJECT_NAME} ${QT_LIBRARIES} ${catkin_LIBRARIES}
Using this cmake file and package xml and description xml following official rviz plugin tutorial, I went through catkin_make process smoothly and harvest my lib_pkg.so successfully.
Then launching process for Rviz went on smoothly, and I can even see my panel in the add_new_panel list.
But when I click on it to open it, ROS pumped out an ERROR:
PluginlibFactory: The plugin for class 'framefab_mpp/FrameFabRvizPanel' failed to load.  Error: Failed to load library /home/yijiangh/catkin_ws/devel/lib//libframefab_mpp.so. Make sure that you are calling the PLUGINLIB_EXPORT_CLASS macro in the library code, and that names are consistent between this macro and your XML. Error string: Could not load library (Poco exception = /home/yijiangh/catkin_ws/devel/lib//libframefab_mpp.so: undefined symbol: _ZTVN8framefab17FrameFabRvizPanelE)
(Exactly the same symptom @mcholewi has encountered in his thread)
When using rospack plugins --attrib=plugin rviz, I can successfully see the plugin_description.xml address for my pkg.
After getting stuck for 3 days, I happened to see this thread in stackoverflow. And it just saved huge amount of my time!
So change my CMakeLists.txt file like this:
change this line:
into
**add_library(${PROJECT_NAME} ${SRC_FILES} ${HEADER_FILES})**
And everything just works like a charm.
I think the reason can be found at CMake AUTOMOC official doc:
If an #include statement like #include "moc_foo.cpp" is found, the Q_OBJECT class declaration is expected in the header, and moc is run on the header file. A moc_foo.cpp file will be generated from the source’s header into the CMAKE_CURRENT_BINARY_DIR directory. This allows the compiler to find the included moc_foo.cpp file regardless of the location the original source. However, if multiple source files in different directories do this then their generated moc files would collide. In this case a diagnostic will be issued.
So in my previous mistake, the QObject declaration cannot be found thus pluginlib found my customized panel (FrameFabRvizPanel in my case) is undefined.
Thus the solution would be:
  • You can put cpp and header files for your rviz related plugin together in one folder
  • or use the technique stated above (link both source and header to your created library)
Originally posted by yijiangh with karma: 131 on 2017-04-17
Post score: 9
Comment by clyde on 2017-11-19:
This solved my problem as well! My directory structure is slightly different. I replaced this line:
add_library(orca_topside src/orca_panel.cpp)
with this line:
add_library(orca_topside src/orca_panel.cpp include/orca_topside/orca_panel.h)
And it worked!
Comment by martin1412 on 2018-05-11:
Thank you, solved it for me as well
