Hi,
I am running RViz on ROS Indigo and just by doing rosrun rviz rviz the display is blank, showing no data (not even the grid). I know it works because I can click and drag, the topics such as 2D Nav Goal work or I can see the view changing. If I resize the rviz window then the blank screen looks weird (deformed vision and lines from the previous background). I have seen other similar issues on VM machines but the issues didn't fix my case.
Some more data: I am using a Lenovo Thinkpad E550 with Radeon R7 M260 graphics card, using the default Ubuntu 14.04.05 drivers (because if I install others it will not work).
[ INFO] [1478886940.755808950]: rviz version 1.11.15 [ INFO] [1478886940.755870091]: compiled against Qt version 4.8.6 [ INFO] [1478886940.755884163]: compiled against OGRE version 1.8.1 (Byatis) [ INFO] [1478886940.856285919]: Stereo is NOT SUPPORTED [ INFO] [1478886940.856367826]: OpenGl version: 3 (GLSL 1.3).
Any advice or recommendation?
Thanks!
Originally posted by Javier V. Gómez on ROS Answers with karma: 1305 on 2016-11-11
It seems that I was able to fix it by running [1]:
sudo apt-get install --install-recommends xserver-xorg-lts-utopic libqt5gui5 libgles1-mesa-lts-utopic libgles2-mesa-lts-utopic libgl1-mesa-glx-lts-utopic libgl1-mesa-glx-lts-utopic:i386 libglapi-mesa-lts-utopic:i386 libegl1-mesa-drivers-lts-utopic
sudo apt-get install linux-generic-lts-vivid
However I am not entirely sure if this was the only thing, as I also run previously [2]:
sudo add-apt-repository ppa:oibaf/graphics-drivers
sudo apt-get update
sudo apt-get dist-upgrade
References: 1 2
Originally posted by Javier V. Gómez with karma: 1305 on 2016-11-11
Comment by Javier V. Gómez on 2016-11-11:
Typical case in which I was looking for the answer for about 2 hours, I decide to post and then I find it in 5 minutes...
