I'm using Ubuntu 16.04 I had ROS Kinetic installed following the tutorial and it was working. I was experiencing errors with a tutorial, covered here, so I removed ROS in order to do a complete fresh install. I did so by using:
sudo apt-get remove ros-kinetic-desktop-full
sudo apt-get remove python-rosinstall
sudo rm -fr /etc/ros
sudo rm -fr /opt/ros
sudo rm -fr ~/.ros
sudo apt-get autoremove
To purge my system of my first ROS install.
I then reapplied all the directions given in the installation tutorial.
It seems however the the 'setup.bash' file is not installed the second time around. When I ls /opt/ros/kinetic I get only the following:
philglau@phil-glau-ubuntu-16:/opt/ros/kinetic$ ls
bin  etc  include  lib  share
The 'setup.bash' script is missing !! (using du -hs indicates there are 145MB of other files in this /kinetic folder, so it's not like it didn't install most of the stuff.) Furthermore, when I installed the second time, it gave absolutely no errors or warning to indicate that something was missing or wrong.
This is from dpkg -l
philglau@phil-glau-ubuntu-16:~$ dpkg -l | grep ros-kinetic-catkin
ii  ros-kinetic-catkin                           0.7.6-0xenial-20170217-212821-0800                    amd64        Low-level build system macros and infrastructure for RO
Can't figure out why this is. Did I do something incorrect when uninstalling the original version like forget some other cache or directory??
Is it possible to just manually install the missing setup.bash script? If so where would I get it?
Thank you in advance for your help.
Originally posted by philglau on ROS Answers with karma: 248 on 2017-03-18
Not sure, but it could be that apt did not remove ros-kinetic-catkin with the autoremove, and then when you installed everything the second time, dependency resolution determined that the package ros-kinetic-catkin was already installed, so it skipped it.
But because you rm -fr /opt/ros before, the files are not actually there anymore.
Can you check whether a sudo apt-get install --reinstall ros-kinetic-catkin gets the files back?
Btw: I would never (well, never ..) rm -rf files or directories that were installed by a package manager. Use apt-get remove or apt-get purge with a regex or a package list. If there are still files left after running that, then removing them manually could be acceptable.
Originally posted by gvdhoorn with karma: 86574 on 2017-03-19
Comment by philglau on 2017-03-19:
Thank you for the advice regarding using remove and purge. I will use that going forward. I ran sudo apt-get install --reinstall ros-kinetic-catkin and it does appear to have placed the missing files into /opt/ros/kinetic/. Thank you.
I should have been clearer above I had actually run sudo apt autoremove prior to running the rm -fr commands. After running sudo apt autoremove, I was still left with a /opt/ros/kenetic/ directory, that was mostly empty except for folders, thus the rm -fr to get rid of final remnants.
Comment by luisfelipewb on 2018-11-07:
More than on year later, I had exactly the same problem and the same solution worked for me :) Thanks!
