ubuntu 14.04, ros indigo
It seems like something exists in multiple packages. How to fix it? image description
shawn@evashawn:/opt/ros/indigo/share$ sudo apt-get install ros-indigo-moveit-kinematics Reading package lists... Done Building dependency tree
Reading state information... Done The following NEW packages will be installed: ros-indigo-moveit-kinematics 0 upgraded, 1 newly installed, 0 to remove and 533 not upgraded. 2 not fully installed or removed. Need to get 0 B/131 kB of archives. After this operation, 687 kB of additional disk space will be used. (Reading database ... 282423 files and directories currently installed.) Preparing to unpack .../ros-indigo-moveit-kinematics_0.7.8-0trusty-20170328-004135-0700_amd64.deb ... Unpacking ros-indigo-moveit-kinematics (0.7.8-0trusty-20170328-004135-0700) ... dpkg: error processing archive /var/cache/apt/archives/ros-indigo-moveit-kinematics_0.7.8-0trusty-20170328-004135-0700_amd64.deb (--unpack): trying to overwrite '/opt/ros/indigo/include/moveit/srv_kinematics_plugin/srv_kinematics_plugin.h', which is also in package ros-indigo-moveit-ros-planning 0.7.2-0trusty-20161115-195213-0800 dpkg-deb: error: subprocess paste was killed by signal (Broken pipe) Errors were encountered while processing: /var/cache/apt/archives/ros-indigo-moveit-kinematics_0.7.8-0trusty-20170328-004135-0700_amd64.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
Originally posted by shawnysh on ROS Answers with karma: 339 on 2017-05-03
First try sudo apt-get update/upgrade then do installation. Hope this will help.
Originally posted by Waleed_Shahzaib with karma: 49 on 2017-05-03
Comment by shawnysh on 2017-05-03:
I try to sudo apt-get -f upgrade, and then it works. Thanks. But I wonder does forcing to upgrade cause some compatible problems afterwards?
