I installed a ros package wih this command:
$ sudo apt-get install ros-kinetic-novatel-gps-driver
Now I would like to remove this package and build it from its github page. What is the safest and cleanest way to do so?
I am aware of:
$ sudo apt remove ros-kinetic-novatel-gps-driver
or
$ sudo apt-get purge ros-kinetic-novatel-gps-driver
cheers,
Originally posted by Farid on ROS Answers with karma: 165 on 2019-12-06
Comment by gvdhoorn on 2019-12-06:
This is not ROS-specific. apt (and apt-get) are tools provided by Debian (and Debian based Linux distributions such as Ubuntu).
remove and purge are exactly the two options you have to remove the Debian package.
I think there is no need to remove it. You can build it from your github page again and swtich which version you want to use by running the command source devel/setup.bash in your ROS workspace.
Hope it helps.
Originally posted by nofear123 with karma: 16 on 2019-12-06
