Hi,
I am trying to install rqt-plot (I am running ROS Kinetic on Ubuntu 16.04).
When running sudo apt-get install ros-kinetic-rqt-plot I get the following error:
Err:1 http://packages.ros.org/ros/ubuntu xenial/main amd64 ros-kinetic-qt-gui-py-common amd64 0.3.11-0xenial-20180830-074357-0800 404 Not Found [IP: 140.211.166.134 80]
Err:2
http://packages.ros.org/ros/ubuntu xenial/main amd64 ros-kinetic-qwt-dependency amd64 1.1.0-0xenial-20180809-134545-0800 404 Not Found [IP: 140.211.166.134 80]
Err:3
http://packages.ros.org/ros/ubuntu xenial/main amd64 ros-kinetic-rqt-py-common amd64 0.5.0-0xenial-20190320-153730-0800 404 Not Found [IP: 140.211.166.134 80]
Err:4
http://packages.ros.org/ros/ubuntu xenial/main amd64 ros-kinetic-rqt-plot amd64 0.4.8-0xenial-20190320-171954-0800 404 Not Found [IP: 140.211.166.134 80]
E: Failed to fetch
http://packages.ros.org/ros/ubuntu/pool/main/r/ros-kinetic-qt-gui-py-common/ros-kinetic-qt-gui-py-common_0.3.11-0xenial-20180830-074357-0800_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
E: Failed to fetch http://packages.ros.org/ros/ubuntu/pool/main/r/ros-kinetic-qwt-dependency/ros-kinetic-qwt-dependency_1.1.0-0xenial-20180809-134545-0800_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
E: Failed to fetch http://packages.ros.org/ros/ubuntu/pool/main/r/ros-kinetic-rqt-py-common/ros-kinetic-rqt-py-common_0.5.0-0xenial-20190320-153730-0800_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
E: Failed to fetch http://packages.ros.org/ros/ubuntu/pool/main/r/ros-kinetic-rqt-plot/ros-kinetic-rqt-plot_0.4.8-0xenial-20190320-171954-0800_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I can ping packages.ros.org and 140.211.166.134 , so it doesn't seem to be a connectivity issue...
Any ideas on what's going on and how to fix it and proceed with the installation?
SOLUTION: as commented by @gvdhoorn the key has to be updated as described in #q325039.
Then run sudo apt update :
Obj:1 http://es.archive.ubuntu.com/ubuntu xenial InRelease
Obj:2 http://es.archive.ubuntu.com/ubuntu xenial-updates InRelease
Obj:3 http://es.archive.ubuntu.com/ubuntu xenial-backports InRelease
Ign:4 http://dl.google.com/linux/chrome/deb stable InRelease
Des:5 http://security.ubuntu.com/ubuntu xenial-security InRelease [109 kB]
Obj:6 http://dl.google.com/linux/chrome/deb stable Release
Des:7 http://packages.ros.org/ros/ubuntu xenial InRelease [4.678 B]
Des:9 http://packages.ros.org/ros/ubuntu xenial/main amd64 Packages [785 kB]
Des:10 https://packagecloud.io/AtomEditor/atom/any any InRelease [23,2 kB]
Ign:10 https://packagecloud.io/AtomEditor/atom/any any InRelease
Des:11 http://packages.ros.org/ros/ubuntu xenial/main i386 Packages [561 kB]
Descargados 1.483 kB en 3s (396 kB/s)
Leyendo lista de paquetes... Hecho
Originally posted by iabadia on ROS Answers with karma: 55 on 2019-06-12
This could be caused by the issue described in #q325039. Could you check?
If you already have the correct key, can you verify that sudo apt update completes successfully? It might help if you post the output of that command here (not in a comment, append it to your original question text, use the edit button/link for that).
Originally posted by gvdhoorn with karma: 86574 on 2019-06-12
