Hi to everybody
I have installed debian squeeze and I follow ROS Electric installation instructions
I do the following:
1.-# apt-get install build-essential python-yaml cmake subversion wget python-setuptools mercurial
2.-# easy_install -U rosinstall
3.-# rosinstall ~/ros "http://packages.ros.org/cgi-bin/gen_rosinstall.py?rosdistro=electric&variant=desktop-full&overlay=no"
4.- # source ~/ros/setup.bash
I can see that /opt/ros/electric/setup.bash doest exist /op/ is empty. And, I can not create a bash script for configuring your ROS workspace environment.
Any ideas? I have no clue, I will aprreciate any help.
Regards,
Alfredo
Originally posted by acp on ROS Answers with karma: 556 on 2011-11-08
With the rosinstall command as above, everything is installed in ~/ros. So instead of using /opt/ros/electric, using ~/ros should get you going.
Originally posted by Steven Bellens with karma: 735 on 2011-11-08
Post score: 4
Comment by Steven Bellens on 2011-11-09:
#!/bin/sh source ~/ros/setup.bash export ROS_ROOT=~/ros export PATH=$ROS_ROOT/bin:$PATH export PYTHONPATH=$ROS_ROOT/core/roslib/src:$PYTHONPATH export ROS_PACKAGE_PATH=~/ros:$ROS_PACKAGE_PATH
Comment by acp on 2011-11-08:
I am still a bit confuse. The question is now, how a bash script to configure a work space environment shall be? as stated in the tutorial http://www.ros.org/wiki/ROS/Tutorials/InstallingandConfiguringROSEnvironment
Comment by Steven Bellens on 2011-11-08:
The tutorials are mainly written assuming the default Ubuntu installation, which installs in /opt/ros/electric. As you are using Debian and build ROS from source, the installation directory is different in your case. So yes, in your case it's "source ~/ros/setup.bash"
I see, well, why the tutorial points to "source /opt/ros/electric/setup.bash" for the script for the ROS workspace environment. it shall be I guess "source ~/ros/setup.bash" for the script, right?
