I am trying to install ROS on raspberry pi 2 model b. The ubuntu-mate 16.04 OS is installed. During environment setup I am getting /opt/ros/kinetic/setup.bash: No such file or dirctory error.
Whats the solution?
Thank You.
Originally posted by malgudi on ROS Answers with karma: 88 on 2017-01-30
Comment by gvdhoorn on 2017-01-30:
Are you sure the earlier commands completed successfully? If you don't have that file, I fear that you haven't installed ROS at all.
Comment by malgudi on 2017-01-31:
Well I tried to install it again everything from start, there was problem in installing rosdep then i followed #q32875 this page but I again i faced same problem during environment setup.
Can I install Indigo ROS on ubuntu-mate 16.04??
Comment by S_Lzrnk on 2017-01-31:
Indigo officially does't Ubuntu 16.04 link text Kinectic works fine on Raspberry Pi with Mate 16.04
Comment by gvdhoorn on 2017-01-31:
As @S_Lzrnk mentions, Indigo is not supported on 16.04, but Kinetic should be. I'm not sure about RPi2 binary builds though.
HI... I got the solution. If you use the command
sudo apt-get update --fix-missing
this will solve the problem.
Originally posted by malgudi with karma: 88 on 2017-01-31
Comment by 1at7 on 2019-08-02:
not fixing the problem for me for same error
