Hi!
I'm looking into the tutorials on URDF (ROS Indigo), robot_state_publisher etc. In this tutorial it is stated that
roslaunch urdf_tutorial display.launch model:=urdf/01-myfirst.urdf
should start rviz
(launch parameters stored inside display.launch
) with the selected model. Sadly I'm getting the error that such file cannot be found:
rosuser:~$ roslaunch urdf_tutorial display.launch model:=urdf/01-myfirst.urdf
... logging to /home/rosuser/.ros/log/336d620e-8d02-11e5-b0c5-90fba64806be/roslaunch-latadmin-ros-7550.log
Press Ctrl-C to interrupt
File "/opt/ros/indigo/lib/python2.7/dist-packages/roslaunch/__init__.py", line 298, in main
p.start()
File "/opt/ros/indigo/lib/python2.7/dist-packages/roslaunch/parent.py", line 260, in start
self._start_infrastructure()
File "/opt/ros/indigo/lib/python2.7/dist-packages/roslaunch/parent.py", line 209, in _start_infrastructure
self._load_config()
File "/opt/ros/indigo/lib/python2.7/dist-packages/roslaunch/parent.py", line 124, in _load_config
roslaunch_strs=self.roslaunch_strs, verbose=self.verbose)
File "/opt/ros/indigo/lib/python2.7/dist-packages/roslaunch/config.py", line 451, in load_config_default
loader.load(f, config, verbose=verbose)
File "/opt/ros/indigo/lib/python2.7/dist-packages/roslaunch/xmlloader.py", line 730, in load
self._load_launch(launch, ros_config, is_core=core, filename=filename, argv=argv, verbose=verbose)
File "/opt/ros/indigo/lib/python2.7/dist-packages/roslaunch/xmlloader.py", line 702, in _load_launch
self._recurse_load(ros_config, launch.childNodes, self.root_context, None, is_core, verbose)
File "/opt/ros/indigo/lib/python2.7/dist-packages/roslaunch/xmlloader.py", line 646, in _recurse_load
self._param_tag(tag, context, ros_config, verbose=verbose)
File "/opt/ros/indigo/lib/python2.7/dist-packages/roslaunch/xmlloader.py", line 95, in call
return f(*args, **kwds)
File "/opt/ros/indigo/lib/python2.7/dist-packages/roslaunch/xmlloader.py", line 264, in _param_tag
value = self.param_value(verbose, name, ptype, *vals)
File "/opt/ros/indigo/lib/python2.7/dist-packages/roslaunch/loader.py", line 463, in param_value
with open(textfile, 'r') as f:
IOError: [Errno 2] No such file or directory: u'urdf/01-myfirst.urdf'
I also read the lines below:
This launch file assumes that 01-myfirst.urdf is in the urdf subdirectory of the directory that you type the command in. Otherwise, you should say model:='$(find pkg-name)/urdf/01-myfirst.urdf' where pkg-name is the name of the package that the file is in (single quotes required)
I tried both with an installed version of the package and a fresh download of the package inside my catkin workspace
but in both cases I'm getting the same error. I have checked and the urdf
folder is there along with the specified file (last line of the following terminal output):
rosuser:/opt/ros/indigo/share/urdf_tutorial$ ls -R
cmake images launch package.xml urdf urdf.rviz urdf.vcg
./cmake:
urdf_tutorialConfig-version.cmake urdf_tutorialConfig.cmake
./images:
flexible.png materials.png multipleshapes.png myfirst.png origins.png visual.png
./launch:
display.launch gazebo.launch xacrodisplay.launch
./urdf:
01-myfirst.urdf 02-multipleshapes.urdf 03-origins.urdf 04-materials.urdf 05-visual.urdf 06-flexible.urdf 07-physics.urdf 08-macroed.urdf.xacro r2d2.xacro
Does anyone have an idea what is going on here? I've looked into the launch
file and from what my poor knowledge on the topic tells me is that it should be working.
Originally posted by rbaleksandar on ROS Answers with karma: 299 on 2015-11-17
Comment by gvdhoorn on 2015-11-17:
Please add the exact error message to your original post (use the edit button/link). Also: which version of ROS, how installed, etc.
Comment by rbaleksandar on 2015-11-17:
Done, although the error message doesn't say much (even by looking at the trace) and also I don't get the "how installed" part.
