I am adding support of dynamic reconfigure to a node following this tutorial. ( http://wiki.ros.org/dynamic_reconfigure/Tutorials/SettingUpDynamicReconfigureForANode ). code is same as written in tutorial.
Problem: loading dynamic parameter in rqt_reconfigure gui
System Configuration : ROS Groovy on Ubuntu 12.04 LTS
Error : when selecting dynamic_reconfigure node in rqt_gui
[INFO] [WallTime: 1384492760.076999] reconf loading #1/1 0.0 / 0.0sec node=/dynamic_reconfigure_node Traceback (most recent call last):
File "/opt/ros/groovy/lib/python2.7/dist-packages/rqt_reconfigure/node_selector_widget.py", line 248, in _selection_changed_slot self._selection_selected(index_current, rosnode_name_selected) File "/opt/ros/groovy/lib/python2.7/dist-packages/rqt_reconfigure/node_selector_widget.py", line 198, in _selection_selected item_widget = item_child.get_dynreconf_widget()
File "/opt/ros/groovy/lib/python2.7/dist-packages/rqt_reconfigure/treenode_qstditem.py", line 148, in get_dynreconf_widget self._param_name_raw) File "/opt/ros/groovy/lib/python2.7/dist-packages/rqt_reconfigure/dynreconf_client_widget.py", line 57, in init group_desc, node_name) File "/opt/ros/groovy/lib/python2.7/dist-packages/rqt_reconfigure/param_groups.py", line 152, in init self._create_node_widgets(config) File "/opt/ros/groovy/lib/python2.7/dist-packages/rqt_reconfigure/param_groups.py", line 198, in _create_node_widgets widget = eval(_GROUP_TYPES[group['type']])(self.updater, group) File "/opt/ros/groovy/lib/python2.7/dist-packages/rqt_reconfigure/param_groups.py", line 247, in init super(BoxGroup, self).init(updater, config) TypeError: init() takes exactly 4 arguments (3 given)
Snapshot of rqt_reconfigure GUI http://www.freeimagehosting.net/newuploads/uacce.png
However if i remove grouping of parameter
angles = gen.add_group("Angles") and change
angles.add(.....) to -> gen.add(....)
Every thing works !!!
snapshot of rqt_reconfigure http://www.freeimagehosting.net/newuploads/ivsir.png
i want to change parameter of many sensors dynamically for that i need sensor grouping. Searched a lot for solution but not able to find solution. Please help.
Originally posted by AbhishekMehta on ROS Answers with karma: 226 on 2013-11-14
Grouping is not yet implemented and a ticket is there with which I haven't arranged time to implement. Patch is very much appreciated.
Originally posted by 130s with karma: 10937 on 2013-11-15
