I have been learning segmatch lately,and I refer to a website :
https://github.com/ethz-asl/segmatch/wiki/Demonstrations
when I run:
roslaunch laser_mapper kitti_loop_closure.launch
it can work but will show an error:
auto-starting new master process[master]: started with pid [3377] ROS_MASTER_URI=http://localhost:11311 setting /run_id to bfa6c998-76b9-11e7-ac3e-4d4164e69652 process[rosout-1]: started with pid [3390] started core service [/rosout] process[visualizer-2]: started with pid [3414] ERROR: cannot launch node of type [laser_mapper/laser_mapper_node]: can't locate node [laser_mapper_node] in package [laser_mapper] process[player-4]: started with pid [3415] [ INFO] [1501592582.709331783]: Opening /home/wang/catkin_ws/src/segmatch/laser_mapper/demonstration_files/kitti/2011_09_30_drive_18.bag [ INFO] [1501592585.277767713]: rviz version 1.11.16 [ INFO] [1501592585.277887573]: compiled against Qt version 4.8.6 [ INFO] [1501592585.277936305]: compiled against OGRE version 1.8.1 (Byatis) [ INFO] [1501592586.765014947]: Stereo is NOT SUPPORTED [ INFO] [1501592586.765184765]: OpenGl version: 3 (GLSL 1.3). Waiting 0.2 seconds after advertising topics... done. Hit space to toggle paused, or 's' to step. [RUNNING] Bag Time: 1317376766.767944 Duration: 287.535898 / 287.641810
Done. [player-4] process has finished cleanly log file: /home/wang/.ros/log/bfa6c998-76b9-11e7-ac3e-4d4164e69652/player-4*.log [visualizer-2] process has finished cleanly log file: /home/wang/.ros/log/bfa6c998-76b9-11e7-ac3e-4d4164e69652/visualizer-2*.log
When I open this directory but not find this file.This directory has:
master.log roslaunch-me-3365.log rosout-1-stdout.log rosout.log
In the master.log file,some of the errors are displayed
[rosmaster.threadpool][ERROR] 2017-08-01 21:09:51,029: Traceback (most recent call last): File "/opt/ros/indigo/lib/python2.7/dist-packages/rosmaster/threadpool.py", line 218, in run result = cmd(*args) File "/opt/ros/indigo/lib/python2.7/dist-packages/rosmaster/master_api.py", line 208, in publisher_update_task xmlrpcapi(api).publisherUpdate('/master', topic, pub_uris) File "/usr/lib/python2.7/xmlrpclib.py", line 1233, in call return self.__send(self.__name, args) File "/usr/lib/python2.7/xmlrpclib.py", line 1587, in __request verbose=self.__verbose File "/usr/lib/python2.7/xmlrpclib.py", line 1273, in request return self.single_request(host, handler, request_body, verbose) File "/usr/lib/python2.7/xmlrpclib.py", line 1306, in single_request return self.parse_response(response) File "/usr/lib/python2.7/xmlrpclib.py", line 1482, in parse_response return u.close() File "/usr/lib/python2.7/xmlrpclib.py", line 794, in close raise Fault(**self._stack[0]) Fault: <Fault -1: 'publisherUpdate: unknown method name'>
what can I do?Thanks!
Originally posted by nature1949 on ROS Answers with karma: 1 on 2017-08-01
The error ERROR: cannot launch node of type [laser_mapper/laser_mapper_node]: can't locate node [laser_mapper_node] in package [laser_mapper]seems to be regarding build/finding the node laser_mapper_node. Make sure the package laser_mapper is built and sourced, and check if you can run rosrun laser_mapper laser_mapper_node
Originally posted by naveedhd with karma: 161 on 2017-08-02
