Hey i'm new in ROS. I've been tried to launch moveit! roslaunch moveit_setup_assistant setup_assistant.launch i'd got these error "SyntaxError: invalid syntax ". These are my traceback:
  File "/opt/ros/melodic/bin/roslaunch", line 34, in <module>
    import roslaunch
  File "/opt/ros/melodic/lib/python2.7/dist-packages/roslaunch/__init__.py", line 62, in <module>
    from .scriptapi import ROSLaunch
  File "/opt/ros/melodic/lib/python2.7/dist-packages/roslaunch/scriptapi.py", line 42, in <module>
    import roslaunch.parent
  File "/opt/ros/melodic/lib/python2.7/dist-packages/roslaunch/parent.py", line 54, in <module>
    import roslaunch.server
  File "/opt/ros/melodic/lib/python2.7/dist-packages/roslaunch/server.py", line 79, in <module>
    from rosgraph_msgs.msg import Log
  File "/opt/ros/dashing/lib/python3.6/site-packages/rosgraph_msgs/msg/__init__.py", line 1, in <module>
    from rosgraph_msgs.msg._clock import Clock  # noqa: F401
  File "/opt/ros/dashing/lib/python3.6/site-packages/rosgraph_msgs/msg/_clock.py", line 56
    class Clock(metaclass = Metaclass_Clock):
And these might be related error but i've feel doesn't help :https://answers.ros.org/question/221035/ros-scripts-and-python-related-error/ Please I need help, and anybody have suggestion ?
Originally posted by Augustine_Sena on ROS Answers with karma: 1 on 2020-03-18
We see this:
and:
which suggests you have both ROS 1 Melodic and ROS 2 Dashing installed on your machine.
Moreover, you probably also have both ROS versions sourced in the same shell. Do you have two source /opt/ros/.../setup.bash lines in your .bashrc by any chance?
If so, remove the one for ROS 2 for now and see whether things start working.
Originally posted by gvdhoorn with karma: 86574 on 2020-03-18
It is probably because you are running ROS under python 2.7 and in your code you are using Python 3 syntax for metaclass definition. So i would say there is a mixure of Python versions.
Comment by gvdhoorn on 2020-03-18:
The traceback makes reference to ROS Dashing, which is a ROS 2 version which makes use of Python 3. So that would be expected.
What the OP needs to do is sort out in which order he sources things, and/or whether he even needs to source both ROS versions at the same time.
