after running 'rosdep update', it shows:
reading in sources list data from /etc/ros/rosdep/sources.list.d
Hit http://github.com/ros/rosdistro/raw/master/rosdep/osx-homebrew.yaml
ERROR: unable to process source [http://github.com/ros/rosdistro/raw/master/rosdep/base.yaml]:
<urlopen error _ssl.c:489: The handshake operation timed out> (http://github.com/ros/rosdistro/raw/master/rosdep/base.yaml)
ERROR: error loading sources list:
The read operation timed out
this is my first time to install ROS, and I don't know how to deal with this error.. What I have to do now? Thank you!
Hello demmeln~
after I run python -c 'from urllib2 import urlopen; print(urlopen("http://github.com/ros/rosdistro/raw/master/rosdep/base.yaml", timeout=5).info());'
File "<string>", line 1, in <module>
File "/usr/lib/python2.7/urllib2.py", line 126, in urlopen
return _opener.open(url, data, timeout)
File "/usr/lib/python2.7/urllib2.py", line 406, in open
response = meth(req, response)
File "/usr/lib/python2.7/urllib2.py", line 519, in http_response
'http', request, response, code, msg, hdrs)
File "/usr/lib/python2.7/urllib2.py", line 438, in error
result = self._call_chain(*args)
File "/usr/lib/python2.7/urllib2.py", line 378, in _call_chain
result = func(*args)
File "/usr/lib/python2.7/urllib2.py", line 625, in http_error_302
return self.parent.open(new, timeout=req.timeout)
File "/usr/lib/python2.7/urllib2.py", line 400, in open
response = self._open(req, data)
File "/usr/lib/python2.7/urllib2.py", line 418, in _open
'_open', req)
File "/usr/lib/python2.7/urllib2.py", line 1215, in https_open
return self.do_open(httplib.HTTPSConnection, req)
File "/usr/lib/python2.7/urllib2.py", line 1177, in do_open
raise URLError(err)
urllib2.URLError: <urlopen error timed out>
now after running rosdep update...:
ERROR: unable to process source [https://github.com/NikolausDemmel/rosdistro/raw/master/rosdep/osx-homebrew.yaml]:
<urlopen error _ssl.c:489: The handshake operation timed out> (https://github.com/NikolausDemmel/rosdistro/raw/master/rosdep/osx-homebrew.yaml)
Hit https://github.com/NikolausDemmel/rosdistro/raw/master/rosdep/gentoo.yaml
ERROR: unable to process source [https://github.com/NikolausDemmel/rosdistro/raw/master/rosdep/base.yaml]:
<urlopen error _ssl.c:489: The handshake operation timed out> (https://github.com/NikolausDemmel/rosdistro/raw/master/rosdep/base.yaml)
really thank you demmeln~
Originally posted by liuhyuu on ROS Answers with karma: 15 on 2014-03-31
Comment by liuhyuu on 2014-04-02:
if you have the same problem .maybe you can try to repeat the command 'rosdep update'.. I don't know what happened but sometimes it really works ..
