Hello all!
I am following the Raspberry Pi (Raspbian) Source install tutorial after installing most packages from the repository on http://www.ros.org/wiki/groovy/Installation/Raspbian but I am getting this file not found erros:
pi@raspberrypi ~ $ sudo rosdep update > reading in sources list data from > /etc/ros/rosdep/sources.list.d Hit > https://github.com/ros/rosdistro/raw/master/rosdep/osx-homebrew.yaml > Hit > https://github.com/ros/rosdistro/raw/master/rosdep/gentoo.yaml > Hit > https://github.com/ros/rosdistro/raw/master/rosdep/base.yaml > Hit > https://github.com/ros/rosdistro/raw/master/rosdep/python.yaml > Hit > https://github.com/ros/rosdistro/raw/master/rosdep/ruby.yaml > Hit > https://github.com/ros/rosdistro/raw/master/releases/fuerte.yaml > ERROR: unable to process source > [https://github.com/ros/rosdistro/raw/master/releases/groovy.yaml]: > Failed to download target platform data for gbpdistro: > HTTP Error 404: Not Found ERROR: unable to process source > [https://github.com/ros/rosdistro/raw/master/releases/hydro.yaml]: > Failed to download target platform data for gbpdistro: > HTTP Error 404: Not Found updated cache in > /root/.ros/rosdep/sources.cache ERROR: > Not all sources were able to be > updated. [[[ ERROR: unable to process > source > [https://github.com/ros/rosdistro/raw/master/releases/groovy.yaml]: > Failed to download target platform data for gbpdistro: > HTTP Error 404: Not Found ERROR: unable to process source > [https://github.com/ros/rosdistro/raw/master/releases/hydro.yaml]: > Failed to download target platform data for gbpdistro: > HTTP Error 404: Not Found ]]] pi@raspberrypi ~ $
Is it expected behavior?
Thanks!
Edit: Full script:
pi@raspberrypi /etc $ sudo easy_install rosdep Searching for rosdep Best match: rosdep 0.10.15 rosdep 0.10.15 is already the active version in easy-install.pth
Using /usr/lib/pymodules/python2.7 Processing dependencies for rosdep Finished processing dependencies for rosdep pi@raspberrypi /etc $ sudo rosdep init Wrote /etc/ros/rosdep/sources.list.d/20-default.list Recommended: please run
    rosdep update
pi@raspberrypi /etc $ sudo rosdep update reading in sources list data from /etc/ros/rosdep/sources.list.d Hit https://github.com/ros/rosdistro/raw/master/rosdep/osx-homebrew.yaml Hit https://github.com/ros/rosdistro/raw/master/rosdep/gentoo.yaml Hit https://github.com/ros/rosdistro/raw/master/rosdep/base.yaml Hit https://github.com/ros/rosdistro/raw/master/rosdep/python.yaml Hit https://github.com/ros/rosdistro/raw/master/rosdep/ruby.yaml Hit https://github.com/ros/rosdistro/raw/master/releases/fuerte.yaml ERROR: unable to process source [https://github.com/ros/rosdistro/raw/master/releases/groovy.yaml]: Failed to download target platform data for gbpdistro: HTTP Error 404: Not Found ERROR: unable to process source [https://github.com/ros/rosdistro/raw/master/releases/hydro.yaml]: Failed to download target platform data for gbpdistro: HTTP Error 404: Not Found updated cache in /root/.ros/rosdep/sources.cache ERROR: Not all sources were able to be updated. [[[ ERROR: unable to process source [https://github.com/ros/rosdistro/raw/master/releases/groovy.yaml]: Failed to download target platform data for gbpdistro: HTTP Error 404: Not Found ERROR: unable to process source [https://github.com/ros/rosdistro/raw/master/releases/hydro.yaml]: Failed to download target platform data for gbpdistro: HTTP Error 404: Not Found ]]] pi@raspberrypi /etc $
Originally posted by Marco Poli on ROS Answers with karma: 86 on 2013-07-03
There has been a recent change in the rosdistro system, and tools such as rosdep have been updated. I would recommend the following two things:
  1. Make sure rosdep is up to date:
    sudo apt-get update
    sudo apt-get install python-rosdep
  2. Run sudo rosdep init to reinitialize your /etc/ros/rosdep/sources.list.d, then rosdep update to update your local cache
Originally posted by po1 with karma: 411 on 2013-07-03
Comment by Marco Poli on 2013-07-04:
I had just installed rosdep for the first time using "$ sudo easy_install wstool rospkg rosdep". Will try the package version. Just cheked: I am running version 0.10.15, which is the same in the package system. Just reminding: this is a Raspbian, not Ubuntu. Thanks!
Comment by po1 on 2013-07-04:
Raspbian is debian wheezy, and the packages in the repo described in http://www.ros.org/wiki/groovy/Installation/Raspbian are made for debian wheezy (Raspbian). However, the python-* packages might be slightly out of date. As they are only python files, it should be safe to take the official ones.
po1, I am getting the file not found error with the official rosdep, following the tutorial.
Then it means that the ROSPi repo has not been updated with the latest rosdep. Uninstall any version of rosdep and install it from pip: sudo pip install -U rosdep, that should do it
It is indeed outdated. I will get to installing the lastest one and re-check. Thanks!
Comment by po1 on 2013-07-05:
The ROSPi repo has just been updated with the latest python-* packages, including python-rosdep, check it out!
Comment by Marco Poli on 2013-07-05:
This update solved the issue completely. Thank you for the help!
The repository linking from http://www.ros.org/wiki/groovy/Installation/Raspbian was outdated, as pointed out by po1.
It has been updated to contain version 0.10.20 and this solved the issue.
I would like to thank everyone that contributed for their help! Please keep sharing!
Originally posted by Marco Poli with karma: 86 on 2013-07-05
