Hi all,
I have recently upgraded to Ubuntu 12.04, and naturally tried to upgrade to ROS Fuerte. My laptop has the following specifications:
Memory: 1.9 GiB Processor: Intel® Core™2 Duo CPU T8100 @ 2.10GHz × 2 Graphics: Intel® 965GM
OS Type: 64-bit
I have been installing-removing-installing-removing ROS Fuerte again and again and keep on getting the following error.
Selecting previously unselected package ros-fuerte-desktop-full. Unpacking ros-fuerte-desktop-full (from .../ros-fuerte-desktop-full_1.0.0-s1347207966~precise_amd64.deb) ... Errors were encountered while processing: /var/cache/apt/archives/libassimp-dev_2.0.863+dfsg-2_amd64.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
and also the fact that Ubuntu reported error message saying
'Error: Broken count>0' This usually means that your installed packages have unmet dependencies
I upgraded libassimp via synaptic, so now I have libassimp2-d-dev, libassimp3.0 ...
Then, I tried
sudo apt-get -f install
I get the following messages.
Reading package lists... Done Building dependency tree Reading state information... Done Correcting dependencies... Done The following packages were automatically installed and are no longer required: kdesudo update-manager-kde Use 'apt-get autoremove' to remove them. The following extra packages will be installed: libassimp-dev The following NEW packages will be installed: libassimp-dev 0 upgraded, 1 newly installed, 0 to remove and 132 not upgraded. 5 not fully installed or removed. Need to get 0 B/94.4 kB of archives. After this operation, 470 kB of additional disk space will be used. Do you want to continue [Y/n]? Y (Reading database ... 413855 files and directories currently installed.) Unpacking libassimp-dev (from .../libassimp-dev_2.0.863+dfsg-2_amd64.deb) ... dpkg: error processing /var/cache/apt/archives/libassimp-dev_2.0.863+dfsg-2_amd64.deb (--unpack): trying to overwrite '/usr/include/assimp/Compiler/poppack1.h', which is also in package libassimp3.0-r1264-dev 3.0.1264.10-ubuntu1~precise1 No apport report written because MaxReports is reached already Errors were encountered while processing: /var/cache/apt/archives/libassimp-dev_2.0.863+dfsg-2_amd64.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
I have read a few threads on unmet dependencies, still, I'm not sure what to fix.
Thread 1: http://answers.ros.org/question/43369/unmet-dependencies-for-fuerte-desktop-full-on-1204/
Thread 2: http://answers.ros.org/question/42596/unmet-dependency-on-eigen-for-vision-opencv-now-cant-install-or-upgrade-any-fuerte-packages/
Anyhow, ROS is running whenever I call roscore, but I will not be able to create overlay, since I cannot do this (synaptic will prompt me to remove some ros related packages like ros-desktop-full etc):
sudo apt-get install python-rosinstall python-rosdep
in which I will get the following messages
The following packages have unmet dependencies: python-rosinstall : Depends: mercurial but it is not going to be installed Depends: bzr but it is not going to be installed Depends: python-vcstools but it is not going to be installed ros-fuerte-robot-model : Depends: libassimp-dev but it is not going to be installed ros-fuerte-visualization : Depends: libassimp-dev but it is not going to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Any ideas?
Originally posted by whiterose on ROS Answers with karma: 148 on 2012-09-18
Comment by TurtleBot_Fan on 2012-09-19:
Was this the solution?! I have exactly the same problem. I upgraded my Ubuntu from 10.04 to 12.04 and Fuerte will not install due to the same errors as above.
Comment by whiterose on 2012-09-21:
I have not yet found a solution :(.. tried uninstalling 'libassimp2-dev', and then installed 'libassimp2' and then unistalling it, basically i tried every possible libassimp in synaptic.....
Comment by whiterose on 2012-09-25:
solved by removing libassimp3.0 and installed libassimp-dev... allenh1's solution was right.
Try removing libassimp-dev and the other problems you are having trouble with. You likely have a newer version installed.
If this doesn't work, start the system install over. To do this without losing any data, I recommend you install as you usually would, but DO NOT format the drive. Doing so will erase your data. By not formatting the drive, you can keep the data but override the operating system files.
Originally posted by allenh1 with karma: 3055 on 2012-09-18
