hi,i'm new to ros, i was able to run offline RGBD-SLAM package from a bag file,and it work fine,but when i try to send the result point cloud to octomap_server through pressing 'ctrl+M'.The saved bt file is alway be the size of 18k,and only containing one node. Here is the log info I found
[WARN] MessageFilter [target=/map ]: Dropped 100.00% of messages so far. Please turn the [ros.octomap_server.message_notifier] rosconsole logger to DEBUG for more information.
the bag file i record is follow this command:
rosbag record -O filename-prefix /tf /camera/rgb/image_color /camera/rgb/camera_info /camera/depth/image /camera/depth/camera_info
anyway,if i do online rgbdslam, all is ok! could anyone help me out?Any suggestion is appreciate!!
Originally posted by David B on ROS Answers with karma: 11 on 2012-05-01
