Hello,
I'm trying to simulate a map useing turtlebot data. I've been able to build the map if the messages that I publis are tf and scan, but I don't want to record tf because gmaping publishes there.
Insted of this, I try to make the map from odom, scan and joint_states, the topics that only one node publishes on them and affects to gmapping. The thing is that I allways get the same problem:
WARN 1323440435.058256895: MessageFilter [target=/odom ]: Dropped 100.00% of messages so far. Please turn the [ros.gmapping.message_notifier] rosconsole logger to DEBUG for more information.
WARN 1323440435.059003292: MessageFilter [target=/odom ]: The majority of dropped messages were due to messages growing older than the TF cache time. The last message's timestamp was: 1323433160.494893, and the last frame_id was: /kinect_depth_frame
What do you think I could do? It is obvious that has something to do with the time of ros. Is there any option to record the time when recording the data and then play back the time also?
Thanks.
Originally posted by apalomer on ROS Answers with karma: 318 on 2011-12-09
3 Answers 3
I'm not sure that I completely understand your use case. But here's something that might be useful: you can selectively filter messages from a .bag. E.g., to get all the non-tf messages, plus only those tf messages that encode a particular transform:
rosbag filter in.bag out.bag 'topic != "tf" or m.transforms[0].header.frame_id == "odom_combined" and m.transforms[0].child_frame_id == "base_footprint"'
I often do something like this to remove the map->odom transform from a bag so that I can test amcl or gmapping.
Originally posted by Brian Gerkey with karma: 2916 on 2011-12-09
Post score: 4
Comment by apalomer on 2011-12-11:
Sorry Brian, I saw now that the WARN messages had not been published.
http://www.ros.org/wiki/Clock
I think that part of the solution must be arround that. I'll try!
Originally posted by apalomer with karma: 318 on 2011-12-11
I also suggest to use rxconsole for debugging and set the loggers to "DEBUG" (like the error-message suggested). This really helped me a lot in such cases:
http://www.ros.org/wiki/rxconsole
