Hi guys! I'm in trouble with creating the map of the willowgarage (i'm using it just for practice). I think that the problem is related to record the laser scan in the bag. I'm following this procedure for the creation of the bag and of the map:
- roslaunch gazebo_ros willowgarage_world.launch
- insert the robot in the environment
- rosbag record -O example /laser_scan
For the creation of the map:
- roscore
- rosparam set use_sim_time true
- rosrun gmapping slam_gmapping scan:=laser_scan
- rosbag play --clock example
- rosrun map_server map_saver -f map_example
From executing these commands, at the end, the server is waiting for the map without reaching any result. In the gmapping process, I have warning like:
[ WARN] [1500976433.556165904, 15.058000000]: MessageFilter [target=odom ]: Dropped 100.00% of messages so far. Please turn the [ros.gmapping.message_notifier] rosconsole logger to DEBUG for more information.
[ WARN] [1500976494.043539452, 0.045000000]: Detected jump back in time. Clearing TF buffer.
What is the error in the procedure that I'm following? Thanks!
Originally posted by tonio on ROS Answers with karma: 3 on 2017-07-25
