Hi,
I am trying to build ogre_tools using the source present in ROS Diamondback on a 64bit Mac SnowLeopard. I have successfully installed Ogre (after fetching the latest version from their repo) and have placed the Ogre.framework where the ogre_tools build process looks for it. However, I am stuck with this error now,
..... Some output from the make command.... make -f CMakeFiles/python_ogre_tools.dir/build.make CMakeFiles/python_ogre_tools.dir/depend /opt/local/bin/cmake -E cmake_progress_report /Users/sagnikdhar/ros/visualization_common/ogre_tools/CMakeFiles 20 [ 94%] Generating src/ogre_tools/ogre_tools_swig_generated.cpp, lib/ogre_tools.py /opt/local/bin -c++ -Wall -python -modern -new_repr -keyword -fastdispatch -fvirtual -fastinit -fastunpack -I/opt/local/lib/wx/include/gtk2-unicode-release-2.8 -I/opt/local/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXGTK__ -DSWIG_TYPE_TABLE=_wxPython_table -DWXP_USE_THREAD=1 -o /Users/sagnikdhar/ros/visualization_common/ogre_tools/src/ogre_tools/ogre_tools_swig_generated.cpp -outdir ../lib -module ogre_tools /Users/sagnikdhar/ros/visualization_common/ogre_tools/src/ogre_tools/ogre_tools.i
make[2]: /opt/local/bin: Permission denied
make[2]: *** [src/ogre_tools/ogre_tools_swig_generated.cpp] Error 1
make[1]: *** [CMakeFiles/python_ogre_tools.dir/all] Error 2
make: *** [all] Error 2
Any idea what is going wrong ?
I found a discussion thread which discusses a similar problem, however the solution points to a ticket (Ticket ID 818) on the WillowGarage site, but the link seems broken. Any idea how I could track an older ticket on the Willow Garage site ?
Thanks a lot !
~ Sagnik
Originally posted by Sagnik on ROS Answers with karma: 184 on 2011-02-24
Hi,
Thanks for the link to the ticket. However it does not solve my problem completely. From what I understand, ogre_tools_swig_generated.cpp is generated from ogre_tools.py by using swig. But this is failing. When I try to execute the command manually, this is the error that I get ,
"Unable to open file ../lib/ogre_tools.py: No such file or directory"
Does anyone know what could possibly be going wrong ?
Thanks, Sagnik
Originally posted by Sagnik with karma: 184 on 2011-02-24
Comment by Sagnik on 2011-06-23:
We faced a bunch of other issues on using ROS on a mac and decided to move to Ubuntu. So I haven't had a chance to verify if this problem has been fixed.
Comment by Mac on 2011-06-17:
Is this still an issue? How have things progressed?
