i try to make custom messages in my workspace. i follow the tutorial, but when i'm catkin_make workspace, i get erorr like this and i try to catkin_make install and get same error. what should i do?? thank you
mfikih15@lenovo:~/Documents/kapalTenggelam/serverGabut$
catkin_make Base path:
/home/mfikih15/Documents/kapalTenggelam/serverGabut
Source space:
/home/mfikih15/Documents/kapalTenggelam/serverGabut/src
Build space:
/home/mfikih15/Documents/kapalTenggelam/serverGabut/build
Devel space:
/home/mfikih15/Documents/kapalTenggelam/serverGabut/devel
Install space:
/home/mfikih15/Documents/kapalTenggelam/serverGabut/install
Running command: "make cmake_check_build_system" in
"/home/mfikih15/Documents/kapalTenggelam/serverGabut
/build"
-- Using CATKIN_DEVEL_PREFIX: /home/mfikih15/Documents/kapalTenggelam/serverGabut/devel
-- Using CMAKE_PREFIX_PATH: /home/mfikih15/Documents/kapalTenggelam/serverGabut/devel;/home/mfikih15 /Documents/joystick/devel;/home/mfikih15/Documents/kapalTenggelam/robotTenggelam/devel;/home/mfikih15/Documents /pkm/devel;/opt/ros/kinetic
-- This workspace overlays: /home/mfikih15/Documents/kapalTenggelam/serverGabut/devel;/home/mfikih15/Documents/joystick/devel;/home/mfikih15/Documents/kapalTenggelam/robotTenggelam/devel;/home/mfikih15/Documents/pkm/devel;/opt/ros/kinetic
-- Using PYTHON_EXECUTABLE: /usr/local/bin/python
-- Using Debian Python package layout
-- Using empy: /usr/bin/empy
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/mfikih15/Documents/kapalTenggelam/serverGabut/build/test_results
-- Found gtest sources under '/usr/src/gtest': gtests will be built
-- Using Python nosetests: /usr/bin/nosetests-2.7
-- catkin 0.7.6
-- BUILD_SHARED_LIBS is on
-- ~~ traversing 1 packages in topological order:
-- ~~ - groundserver
-- +++ processing catkin package: 'groundserver'
-- ==> add_subdirectory(groundserver)
-- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
-- groundserver: 1 messages, 0 services
-- Configuring done
-- Generating done
-- Build files have been written to: /home/mfikih15/Documents/kapalTenggelam/serverGabut/build
Running command: "make -j4 -l4" in
"/home/mfikih15/Documents/kapalTenggelam/serverGabut/build"
[ 0%] Built target std_msgs_generate_messages_lisp
Scanning dependencies of target
killManual [ 0%] Built target
std_msgs_generate_messages_py Scanning
dependencies of target remoteServer [
9%] Building CXX object
groundserver/CMakeFiles/killManual.dir/src/killManual.cpp.o
[ 9%] Built target
std_msgs_generate_messages_cpp [ 18%]
Building CXX object
groundserver/CMakeFiles/remoteServer.dir/src/remoteServer.cpp.o
[ 18%] Built target
_groundserver_generate_messages_check_deps_inputRemote
[ 18%] Built target
std_msgs_generate_messages_eus [ 18%]
Built target
std_msgs_generate_messages_nodejs [
27%] Built target
groundserver_generate_messages_lisp [
45%] Built target
groundserver_generate_messages_py [
54%] Generating C++ code from
groundserver/inputRemote.msg [ 72%]
Built target
groundserver_generate_messages_eus
File
"/opt/ros/kinetic/share/gencpp/cmake/../../../lib/gencpp/gen_cpp.py",
line 41, in
import genmsg.template_tools   File
"/opt/ros/kinetic/lib/python2.7/dist-packages/genmsg/template_tools.py",
line 39, in
import em ImportError: No module named em [ 81%] Built target
groundserver_generate_messages_nodejs
groundserver/CMakeFiles/groundserver_generate_messages_cpp.dir/build.make:62:
recipe for target
'/home/mfikih15/Documents/kapalTenggelam/serverGabut/devel/include/groundserver/inputRemote.h'
failed make[2]: ***
[/home/mfikih15/Documents/kapalTenggelam/serverGabut/devel/include/groundserver/inputRemote.h]
Error 1 CMakeFiles/Makefile2:690:
recipe for target
'groundserver/CMakeFiles/groundserver_generate_messages_cpp.dir/all'
failed make[1]: ***
[groundserver/CMakeFiles/groundserver_generate_messages_cpp.dir/all]
Error 2 make[1]: *** Waiting for
unfinished jobs.... [ 90%] Linking CXX
executable
/home/mfikih15/Documents/kapalTenggelam/serverGabut/devel/lib/groundserver/killManual
[100%] Linking CXX executable
/home/mfikih15/Documents/kapalTenggelam/serverGabut/devel/lib/groundserver/remoteServer
[100%] Built target killManual [100%]
Built target remoteServer
Makefile:138: recipe for target 'all'
failed make: *** [all] Error 2
Invoking "make -j4 -l4" failed
catkin_make install Base path:
Source space:
Build space:
Devel space:
Install space:
Running command: "make install -j4 -l4" in "/home/mfikih15/Documents/kapalTenggelam/serverGabut/build"
[ 0%] Built target std_msgs_generate_messages_lisp [ 36%]
Built target remoteServer [ 36%] Built
target killManual [ 36%] Built target
std_msgs_generate_messages_cpp [ 36%]
Built target
std_msgs_generate_messages_py [ 36%]
Built target
std_msgs_generate_messages_eus [ 36%]
Built target
[ 36%] Built target
54%] Built target
63%] Generating C++ code from
Built target
90%] Built target
[100%] Built target
File
line 41, in
line 39, in
recipe for target
failed make[2]: ***
[/home/mfikih15/Documents/kapalTenggelam/serverGabut/devel/include/groundserver/inputRemote.h] Error 1 CMakeFiles/Makefile2:690:
recipe for target
failed make[1]: ***
Error 2 Makefile:138: recipe for
target 'all' failed make: *** [all]
Error 2 Invoking "make install -j4
-l4" failed mfikih15@lenovo:~/Documents/kapalTenggelam/serverGabut$
Originally posted by lp02781 on ROS Answers with karma: 3 on 2018-01-06
I'm thinking you're running into an issue with the em and empy modules.
See #q257331.
Originally posted by gvdhoorn with karma: 86574 on 2018-01-06
Comment by lp02781 on 2018-01-06:
it work, thank you
