I just pulled down the latest ros-turtle, diamond back and it doesn't seem to build on OSX 64-bit. I'm following along on the install wiki.
And it fails to build with:
Finished
the output log says:
cd build && cmake -Wdev -DCMAKE_TOOLCHAIN_FILE=`rospack find rosbuild`/rostoolchain.cmake .. -- The C compiler identification is GNU -- The CXX compiler identification is GNU -- Checking whether C compiler has -isysroot -- Checking whether C compiler has -isysroot - yes -- Checking whether C compiler supports OSX deployment target flag -- Checking whether C compiler supports OSX deployment target flag - yes -- Check for working C compiler: /usr/bin/gcc -- Check for working C compiler: /usr/bin/gcc -- works -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Checking whether CXX compiler has -isysroot -- Checking whether CXX compiler has -isysroot - yes -- Checking whether CXX compiler supports OSX deployment target flag -- Checking whether CXX compiler supports OSX deployment target flag - yes -- Check for working CXX compiler: /usr/bin/c++ -- Check for working CXX compiler: /usr/bin/c++ -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done [rosbuild] Building package roslib [rosbuild] Cached build flags older than manifests; calling rospack to get flags [rosbuild] Including /Users/mike/Code/ros/ros_comm/clients/roslisp/cmake/roslisp.cmake [rosbuild] Including /Users/mike/Code/ros/ros_comm/clients/rospy/cmake/rospy.cmake [rosbuild] Including /Users/mike/Code/ros/ros_comm/clients/cpp/roscpp/cmake/roscpp.cmake -- Configuring done -- Generating done -- Build files have been written to: /Users/mike/Code/ros/ros/core/roslib/build cd build && make -l4 Scanning dependencies of target rospack_genmsg_libexe [ 0%] Built target rospack_genmsg_libexe Scanning dependencies of target rosbuild_precompile [ 0%] Built target rosbuild_precompile Scanning dependencies of target roslib [100%] Building CXX object CMakeFiles/roslib.dir/src/package.o In file included from /usr/include/architecture/i386/math.h:626, from /usr/include/math.h:28, from /usr/include/c++/4.2.1/cmath:54, from /opt/local/include/boost/config/no_tr1/cmath.hpp:21, from /opt/local/include/boost/date_time/posix_time/posix_time_config.hpp:15, from /opt/local/include/boost/date_time/posix_time/posix_time_system.hpp:13, from /opt/local/include/boost/date_time/posix_time/ptime.hpp:12, from /opt/local/include/boost/date_time/posix_time/posix_time_types.hpp:12, from /opt/local/include/boost/thread/thread_time.hpp:11, from /opt/local/include/boost/thread/locks.hpp:12, from /opt/local/include/boost/thread/pthread/mutex.hpp:12, from /opt/local/include/boost/thread/mutex.hpp:16, from /Users/mike/Code/ros/ros/core/roslib/src/package.cpp:37: /usr/include/AvailabilityMacros.h:108:14: warning: #warning Building for Intel with Mac OS X Deployment Target
Has anyone else seen anything like this? Any help or pointers to a workaround would be much appreciated.
Cheers,
Originally posted by Marrok on ROS Answers with karma: 38 on 2011-03-05
Comment by Marrok on 2011-03-08:
'rosmake roslib' is the part I'm having issue with.
Comment by Eponymous on 2011-03-05:
I'm running ok on the same system. Which step is giving you this problem?
My roslib compile works out-of-the-box (diamondback, 10.6, 64-bit). These lines look very suspicious:
/usr/include/AvailabilityMacros.h:108:14: warning: #warning Building for Intel with Mac OS X Deployment Target < 10.4 is invalid.
Linking CXX shared library ../lib/libroslib.dylib
ld: -rpath can only be used when targeting Mac OS X 10.5 or later
Building for Intel for Mac OS X < 10.4? It looks like your build environment is screwed up. Maybe you have MACOSX_DEPLOYMENT_TARGET set in your environment?
Originally posted by Paul Vernaza with karma: 181 on 2011-03-05
Comment by Marrok on 2011-03-11:
There must have been cruft from a migration I did from an old Mac, I was able to get it to build, although I did have to tweak the install_dirs() in rosboost_cfg.py it seemed to always return the empty string.
Comment by Paul Vernaza on 2011-03-08:
This might also be helpful: http://stackoverflow.com/questions/2211387/python-build-problem-on-mac-os-10-6-snow-leopard
I'm actually building on the same model with no problems. Maybe cmake is incorrectly setting the MACOSX_DEPLOYMENT_TARGET? You can try checking build/CMakeCache.txt (search for OSX) to see if it detects something weird.
I'm also building on the latest rev of Mac Book Pro released on February 24, 2011.
I do not have MACOSX_DEPLOYMENT_TARGET set. Setting it to 10.6 does not seem to help.
