Hi, i am having issue when running roscore.
The error is :
Traceback (most recent call last): File "/opt/ros/electric/ros/bin/roscore", line 34, in from ros import roslaunch File "/opt/ros/electric/ros/core/roslib/src/ros/init.py", line 57, in getattr return import(name) File "/opt/ros/electric/ros_comm/tools/roslaunch/src/roslaunch/init.py", line 53, in from roslaunch.scriptapi import ROSLaunch File "/opt/ros/electric/ros_comm/tools/roslaunch/src/roslaunch/scriptapi.py", line 42, in import roslaunch.parent File "/opt/ros/electric/ros_comm/tools/roslaunch/src/roslaunch/parent.py", line 55, in import roslaunch.server File "/opt/ros/electric/ros_comm/tools/roslaunch/src/roslaunch/server.py", line 70, in from rosgraph_msgs.msg import Log ImportError: No module named rosgraph_msgs.msg
I have try to install python using the following command: sudo easy_install python-yaml
The export | grep ros is :
declare -x PATH="/opt/ros/electric/ros/bin:/opt/ros/electric/ros/bin:/opt/ros/electric/ros/bin:/opt/ros/electric/ros/bin:/opt/ros/electric/ros/bin:/opt/local/bin:/opt/local/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/usr/X11/bin" declare -x PYTHONPATH="/opt/ros/electric/ros/core/roslib/src:/opt/ros/electric/ros/core/roslib/src:/opt/ros/electric/ros/core/roslib/src:/opt/ros/electric/ros/core/roslib/src:/opt/ros/electric/ros/core/roslib/src:" declare -x ROS_PACKAGE_PATH="/opt/ros/electric/robot_model_tutorials:/opt/ros/electric/visualization_tutorials:/opt/ros/electric/geometry_tutorials:/opt/ros/electric/common_tutorials:/opt/ros/electric/ros_tutorials:/opt/ros/electric/documentation:/opt/ros/electric/geometry_experimental:/opt/ros/electric/robot_model_visualization:/opt/ros/electric/geometry_visualization:/opt/ros/electric/diagnostics_monitors:/opt/ros/electric/executive_smach_visualization:/opt/ros/electric/visualization:/opt/ros/electric/slam_gmapping:/opt/ros/electric/navigation:/opt/ros/electric/vision_opencv:/opt/ros/electric/laser_pipeline:/opt/ros/electric/image_pipeline:/opt/ros/electric/image_transport_plugins:/opt/ros/electric/perception_pcl:/opt/ros/electric/image_common:/opt/ros/electric/rx:/opt/ros/electric/visualization_common:/opt/ros/electric/physics_ode:/opt/ros/electric/stage:/opt/ros/electric/simulator_gazebo:/opt/ros/electric/simulator_stage:/opt/ros/electric/xacro:/opt/ros/electric/executive_smach:/opt/ros/electric/robot_model:/opt/ros/electric/assimp:/opt/ros/electric/pluginlib:/opt/ros/electric/orocos_kinematics_dynamics:/opt/ros/electric/nodelet_core:/opt/ros/electric/geometry:/opt/ros/electric/bullet:/opt/ros/electric/filters:/opt/ros/electric/eigen:/opt/ros/electric/driver_common:/opt/ros/electric/diagnostics:/opt/ros/electric/common:/opt/ros/electric/common_msgs:/opt/ros/electric/bond_core:/opt/ros/electric/common_rosdeps:/opt/ros/electric/ros_comm:/opt/ros/electric/ros" declare -x ROS_ROOT="/opt/ros/electric/ros" declare -x ROS_WORKSPACE="/opt/ros/electric"
Please advise. Thank you
Originally posted by halfstopper on ROS Answers with karma: 26 on 2012-05-20
Comment by William on 2012-05-21:
Can you post the output of export | grep ROS? What version of Xcode are you using? Which installation instructions did you use?
Comment by halfstopper on 2012-05-21:
The Xcode version I am using is 3.2.6. I installing ros electric from the link : http://www.ros.org/wiki/electric/Installation/OSX/Homebrew
I install ros to /opt/ros/electric path I am new to installing to mac.
Thank you
The important line from this error is:
"/opt/ros/electric/ros_comm/tools/roslaunch/src/roslaunch/server.py", line 70, in <module> from rosgraph_msgs.msg import Log ImportError: No module named rosgraph_msgs.msg
This means it cannot find the msg module in the rosgraph_msg pkg or it cannot find the rosgraph_msg pkg.
It could be that your environment was not setup correctly, but looking at your feedback to my comment above that doesn't seem to be the problem.
Additionally, it could be that rosgraph_msgs is not built, try running rosmake rosgraph_msgs and then try using roslaunch again. If rosgraph_msgs wasn't built you might have had other issues, make sure you can run rosmake ros ros_comm without failure. This will ensure that everything has been built and generated successfully.
Originally posted by William with karma: 17335 on 2012-05-21
