Hello, I am newbie for the ROS. I am trying to install the package of http://wiki.ros.org/yocs_waypoints_navi, but met the below make issue, I already follow the suggestion from here to run:
 sudo apt-get install ros-kinetic-yocs-velocity-smoother
The installation works fine, and the build already passed, but afdterwards get below issue and compilation terminated:
/catkin_ws/src/yujin_ocs/yocs_joyop/src/joyop.cpp:15:38: fatal error: yocs_msgs/JoystickConfig.h: No such file or directory
compilation terminated.
yujin_ocs/yocs_joyop/CMakeFiles/joyop.dir/build.make:62: recipe for target 'yujin_ocs/yocs_joyop/CMakeFiles/joyop.dir/src/joyop.cpp.o' failed
make[2]: *** [yujin_ocs/yocs_joyop/CMakeFiles/joyop.dir/src/joyop.cpp.o] Error 1
CMakeFiles/Makefile2:8887: recipe for target 'yujin_ocs/yocs_joyop/CMakeFiles/joyop.dir/all' failed
make[1]: *** [yujin_ocs/yocs_joyop/CMakeFiles/joyop.dir/all] Error 2
Makefile:138: recipe for target 'all' failed
make: *** [all] Error 2
Invoking "make -j12 -l12" failed
I already installed the ros-kinetic-yocs-msgs package.
~/catkin_ws$ sudo apt-get install ros-kinetic-yocs-msgs
[sudo] password for liangma:
Reading package lists... Done
Building dependency tree
ros-kinetic-yocs-msgs is already the newest version (0.6.3-0xenial-20181107-005535-0800).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Anyone can help? Thanks so much!!
Originally posted by macleonsh on ROS Answers with karma: 26 on 2019-05-07
Comment by gvdhoorn on 2019-05-07:
Can you tell us why you install yocs_msgs and yocs_velocity_smoother using apt, but then build yocs_joyop from sources?
Sorry I forget detail--later I simply git clone the most update code of ros-kinetic-yocs-msgs from github and do compiling (catkin-make) then it works OK..
Thanks a lot for the feedback anyway.
Originally posted by macleonsh with karma: 26 on 2019-05-11
Comment by macleonsh on 2019-05-15:
@gvdhoorn I can not find the "answered"check box on left side. Can you simply close this ticket ? thanks so much.
Comment by gvdhoorn on 2019-05-15:\
No, I won't close the question.
Instead I've converted your comment to an answer and accepted it for you.
Note though, as explained in #q322980, you should try to avoid building packages from sources, unless you have a good reason to do it. For released packages, there is no reason to go an hunt for all source repositories and maintaining a Catkin workspace in which you build them. Just use apt-get to install the binary packages.
