Hi, I have a fresh install of Ubuntu 13.10 server. I installed ROS hydro base, and follow the examples, but when I'm trying to make the Publiser/Suscriber example (C++) I have the following error
make[2]: *** No rule to make target '/usr/lib/libbost_signals-mt.so', needed by '/home/rosvm/catkin_ws/devel/beginner_tutorials/listener'. Stop.
make[1]: *** [beginner_tutorials/CMakeFiles/listener.dir/all] Error 2
make: *** [all] Error 2 Invoking "make" failed
Originally posted by crhistian on ROS Answers with karma: 11 on 2014-03-02
There is and there will be no Debian packages of Hydro for Ubuntu 13.10. You may either:
Originally posted by Dirk Thomas with karma: 16276 on 2014-03-02
AFAIK ROS Hydro is not yet fully supported on 13.10. Have you installed using the repository or from source?
You can try creating a symbolic link for the needed file
sudo ln -s /usr/lib/x86_64-linux-gnu/libboost_signals.so /usr/lib/libboost_signals-mt.so
or if that does not work you could try installing the libboost-singals package used in 13.04
sudo apt-get install libboost-signals1.49-dev
Originally posted by Gary Servin with karma: 962 on 2014-03-02
Comment by hsu on 2014-07-31:
I ran into the same issue compiling against ros indigo on trusty. soft link trick works well. I think this deserves a ticket on the ros issue tracker.
