When running: sudo apt install ros-melodic-desktop-full
I get the following error:
The following packages have unmet dependencies:
 ros-melodic-desktop-full : Depends: ros-melodic-desktop but it is not going to be installed
                            Depends: ros-melodic-perception but it is not going to be installed
                            Depends: ros-melodic-simulators but it is not going to be installed
                            Depends: ros-melodic-urdf-sim-tutorial but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I have followed the instructions here: http://wiki.ros.org/melodic/Installation/Ubuntu
I am running Ubuntu 18.04
Originally posted by apache8080 on ROS Answers with karma: 1 on 2018-08-01
Comment by gvdhoorn on 2018-08-01:
Do you have Gazebo installed from the osrf repositories by any chance?
When running: sudo rm /var/cache/apt/archives/lock
don't you mean "after running .."? That command only deletes a file, it does not ask apt to install any packages.
Comment by apache8080 on 2018-08-01:
I accidentally put the wrong command in my question. I have now updated it.
Comment by gvdhoorn on 2018-08-02:
But did you install Gazebo sometime earlier and from the OSRF repositories?
Comment by dslowik on 2019-10-27:
Use aptitude as explained here. It guides you through fixing dependencies.
I had the same problem. For me, I ran sudo apt-get install ros-desktop-full before I realized that is not Melodic. I removed that afterwards but I had the same error when I tried to install with sudo apt-get install ros-melodic-desktop-full.
I think the error came from the fact that I had rospkg 1.1.4 instead of 1.1.7 when I installed ros_desktop_full. I did
sudo apt-get remove gazebo9* catkin python-rospkg python-rospkg-modules
(Here, I also removed gazebo9 related packages and catkin that were installed with ros-desktop-full.) Afterwards, I tried to install the melodic desktop full version again and it worked for me.
Originally posted by Catherine Wong with karma: 56 on 2018-08-18
Comment by gvdhoorn on 2018-08-19:
Just for reference: you probably ran into UpstreamPackages.
Comment by sonjabrits on 2020-04-21:
Same happened to me, accidentally first installed ros-desktop-full. Your command worked for me :)
I had encountered the same error. I overcome doing the following steps:-
1.This command will remove gazebo9 ,catkin , python-rospkg , python-rospkg-modules packages from your system
2.This command will remove packages from your system, for example, to remove ros related files:
sudo apt-get remove ros-*
3.This command will remove packages and their configuration files.
sudo apt-get purge ros-*
4.sudo apt-get remove ros-melodic-desktop-full
5.sudo apt-get purge ros-melodic-desktop-full
6.This command will remove dependencies that are no longer needed.
sudo apt-get autoremove
7.sudo apt-get install -f
8.sudo apt-get update
9.sudo apt-get upgrade
10.Now install ros-melodic-desktop-full
References:link text
Originally posted by Neeraj Patil with karma: 21 on 2020-05-05
