Hello,
I'm working with the Sick TIM571 Lidar with ROS-Kinetic on Ubuntu and I'm using the Sick-Tim-ROS-Package. The connection via ethernet works fine and I'm getting distance-datas from the Lidar.
The TIM571 has an angular resolution of 0.333° with an opening angle of 270°. So the lidar should deliver 810 distances.
The problem is, that I'm only getting 270 distances from the lidar.
In the Sopas Tool on Windows the angular resolution is set so 0.333° and I can't change that.
I would be very pleased if someone could help me with that Issue.
Originally posted by Tobias36 on ROS Answers with karma: 1 on 2018-03-22
Comment by mallain on 2019-08-27:
I am experiencing the same issue with both the older sick_tim package and the newer SICK AG supported sick_scan driver package.
Please see this GitHub issue.
Update: see my post below for resolution.
I experienced the same issue with the default configuration on a SICK TiM571, and discovered that I had the median filter option enabled in SOPAS. After disabling this feature and permanently saving to the device, I am now receiving full (0.333 deg) resolution samples from the sick_scan driver.
Credit to SICK support for helping me find diagnose and solve this.
Mitchell
Originally posted by mallain with karma: 16 on 2019-09-01
