sorry for the long post, just want to make sure i include all the details.
I am working on learning ROS2 by building a robot which maps and navigates my apartment.
  • I'm using the RPLidar A1 sensor with the RPLidar package
  • a Robot Create 2 as the chassis with the create_robot package
  • nav2 for navigation
  • slam-toolbox for mapping
and running everything off of a Raspberry Pi 4 4GB with Ubuntu Mate
Currently, I am able to get LIDAR readings to successfully be viewed in RVIZ. I can also get one or two frames of a map to be built. When the robot starts to move, the lidar readings update, but the map itself does not. However, i continue to 'receive' map updates at about 1 every 1.5 seconds.
Here are images from rviz showing the moving scan but with the non-moving map: https://i.stack.imgur.com/CvMDD.jpg
I'm also getting a few errors, from RVIZ i am getting: [rviz]: Message Filter dropping message: frame 'map' at time 1619194935.882 for reason 'Unknown'
from nav2, I am getting [global_costmap.global_costmap_rclcpp_node]: Message Filter dropping message: frame 'laser' at time 1619194959.629 for reason 'Unknown'
My frame map looks like this (Most of the frames are created by the create_robot package): https://i.stack.imgur.com/kns07.jpg
I suspect my issue is with my transforms, either they're configured completely wrong, or there is something small
  • slam_toolbox does the transform from map -> odom
  • the create_robot package has other transforms from base_link to wheels, bumpers, etc and it also publishes odom data
  • using tf2, i'm publishing a transform between base_link and laser and then laser to base_scan.
  • I am also creating a transform from odom to base_footprint because of a ros2 navigation course i was taking on the construct.
Has anyone seen this type of error before? I feel like I am most of the way to the solution but i'm missing something easy
I ended up solving my issue.
Turns out, the create_robot package publishes a transform from odom -> base_footprint. I needed to toy around with my transforms so that:
slam-toolbox created map -> odom
create_robot created odom -> base_footprint
On top of those two things, I had an issue with timing where the transform from map -> base_link did not work either. There was an issue with timings where I was getting the error:
[INFO] [1619986350.507533125] [tf2_echo]: Waiting for transform map -> base_footprint: Lookup would require extrapolation into the past. Requested time 0.200000 but the earliest data is at time 1619986346.813953, when looking up transform from frame [base_footprint] to frame [map]
To solve this error, I just had to call nav2 with the argument use_sim_time:=false
Now that I've done this, everything seems to be working completely fine.
