Hi,
I'm new to ROS. I'm using Ubuntu 12.04 and ROS Hydro. I got a TurtleBot 2 and want to use a laser scanner for mapping and navigation instead of the Kinect. I have a SICK TiM551 (Ethernet). I have already installed the sick_tim driver and the sick_tim551_2050001 node seems to be working fine. I can ping the sensor...
I am looking for a tutorial on how add a SICK TiM lidar to a TurtleBot.
I have already created a map using the Kinect by following the steps in "Build a map with SLAM" Tutorial:
http://wiki.ros.org/turtlebot_navigation/Tutorials/Build%20a%20map%20with%20SLAM
But I want to create and save a map with my SICK Lidar and not with the Kinect.
Thanks,
Originally posted by iraheta28 on ROS Answers with karma: 11 on 2015-01-21
