Hi there!
I'm trying to build my workspace with only hector_slam package inside in my new raspberry pi 3 with this http://www.german-robot.com/2016/05/26/raspberry-pi-sd-card-image/ OS (suggested by the ROS team) but every time I do catkin_make
it freezes in differents %.
Here you have the commands I already tried.
catkin_make
catkin_make -j1
catkin_make_isolated
May be one of you can help me trying to build this workspace.
Originally posted by julimen5 on ROS Answers with karma: 17 on 2017-10-24
Comment by ahendrix on 2017-10-24:
Building on the Raspberry Pi can take hours or days for complex software like hector_slam. How long are you waiting for catkin_make
to finish? Is there any CPU activity while it seems stuck?
Comment by julimen5 on 2017-10-24:
not waiting too match. But it freezes everthig, I can't even move the mouse. Are you telling me I should wait longer?
I opened just one terminal with this command. Tried to echo 3 /proc/sys/vm/drop_caches but I get permission denied.
Comment by rmck on 2017-10-24:
I've had a lot of success by adding additional 1gb swap space and ssh'ing into the pi rather than using the GUI. I run "catkin_make -j1", compilation typically takes 2-3 minutes.
Are you building from source? Hector-Slam should be available as an installable package for 16.04.
It has been compiling for an hour. May be I'll try to disable GUI and do what you are telling me to do.
I did not found it as a installable package
Hmm, it may be worth checking your package configuration. If I run "sudo apt-get install ros-kinetic-hector-slam", I am able to install the hector-slam metapackaged including all its related packages. If you're able to install via apt-get you can skip compilation issues.
I would be very upset if this is my answer
Comment by clyde on 2017-11-07:
What OS is running on the Pi? If Raspbian, you'll need to compile from source. Ubuntu MATE will allow you to install hector-slam from pre-built binaries.
Comment by julimen5 on 2018-01-17:
I'm resuming this work. I saw (this)[https://downloads.ubiquityrobotics.com/pi.html] which are stable version for raspberry pi made by someone aka ubiquityrobotics. So these might be more stable when running ros rather than the raspbian. Ty anyway.
